make instructions don't seem to work on Ubuntu 9.10 - so
kevincrocker
Post by kevincrocker »
I must be doing something wrong - I'm not normally someone who compiles things - so I followed the instructions as set out in the locked admin notice
but, even though all the dependencies were downloaded and appeared to install, the "make -f makefile.linux" command doesn't work - I get all kinds of errors and warnings till finally it dies with an [Error 1] code
so, now what do I do - this sounds like a great program - but, not being able to get past the first step is a bit of a bummer.
Help
skittle
Re: make instructions don't seem to work on Ubuntu 9.10 - so
Post by skittle »
Hi, please post the console output
http://paste.debian.net/
kevincrocker
Well first I'm getting the following errors just simply installing all the dependencies -with Hash Sum mismatch errors:
http://paste.debian.net/65988
skittle
Post by skittle »
Hi again, this is good news! Likely you dont have dependencies installed because its trying to fetch from the CD and not ubuntu online repo
Please post the output of your APT sources.list, it should be in /etc/apt/sources.list
cat /etc/apt/sources.list
kevincrocker
Here's my sources.list
http://paste.debian.net/65999
skittle
Post by skittle »
comment out cd-rom line with '#' with sudo nano sources.list, or your favorite editor.
then do
sudo apt-get update
sudo apt-get upgrade
then try to install makemkv dependencies again
kevincrocker
this worked great - thanks!
now for a serious question :-) how do I get a nice entry in the Applications menu (Sound and Video preferably)
skittle
Post by skittle »
Awesome, I thought that might be the issue! weird that it was trying to fetch from cdrom though...
also do
sudo apt-get autoremove
to get rid of unneeded dependencies
menu items depends on the desktop your using, gnome, kde, xfce... if using gnome:
First i think ubuntu has a built in menu editor, but you can create one on manually too:
in this folder:
"/usr/share/applications" create a file <appname>.desktop
[Desktop Entry]
Name=MakeMKV
Comment=MakeMKV 1.5.2
Type=Application
Exec=/usr/bin/makemkv
Terminal=false
Categories=AudioVideo
More information about menus: http://library.gnome.org/devel/menu-spec/
kevincrocker
Thanks again - simple question though -I know what URI means, but what does it mean -that I have to put in a web URI or a local file system URI - I'm guessing a local file system URIand, does the icon have to be some predetermined size? I found an icon that was 180px x 180px - that seems large
skittle
Post by skittle »
a local image, you can put it /usr/share/icons or /usr/share/pixmaps or wherever you want
icons will be resized to your desktop settings
kevincrocker
Thanks again - all done!
You've been a phenomenal help. Thanks greatly.
