MakeMKV v1.9.5
MacOS: 10.10.5
Attempting backup copy of Mission Impossible 1996 Blu-ray
Error from debug file:
Debug log started at Wed Sep 23 12:58:44 2015 , written by MakeMKV v1.9.5 darwin(x86-release)
001005:0000 MakeMKV v1.9.5 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Bob/MakeMKV_log_1.txt
001003:0020 DEBUG: Code 0 at BiF3`G-tIFtk'uH0W7m$:29398760
002010:0000 Optical drive "BD-RE BUFFALO Optical Drive 2.00d" opened in OS access mode.
005055:0000 Evaluation period has expired, shareware functionality unavailable.
005052:0204 Evaluation period has expired. Please purchase an activation key if you've found this application useful. You may still use all free functionality without any restrictions.
001003:0020 DEBUG: Code 0 at W]$62XZdOk,_EbYa:121264004
001003:0020 DEBUG: Code 0 at W]$62XZdOk,_EbYa:29397403
001003:0020 DEBUG: Code 233 at gjTV0xLIbQ1bICF/pwImO5D8:0
001003:0020 DEBUG: Code 233 at S4ekrWg6YW2xYB3Hw/Jw4SO9:0
Application exited at Wed Sep 23 12:58:53 2015
New to debugging MKV so any ideas / direction welcome...
Re: Mission Impossible 1
Bluray decoding is not "infinitely available" on the unregistered version. It has been so long since I used MakeMKV without a permenant key that I'm fuzzy on how to restart the 30 day clock... You MAY have to uninstall, then re-install v1.9.5.larryebaum wrote:005055:0000 Evaluation period has expired, shareware functionality unavailable.
But try this first:
http://makemkv.com/forum2/viewtopic.php?f=5&t=1053
This message will always have the current beta key in it. Copy the key into your clipboard.
Start MakeMKV. Click on Help, then Register. Paste the key in.
This MAY reset the shareware timer; I don't know.
Thanks...
I've always assumed that message always appeared but I usually don't rip Bluray. I had literally just installed the new version so I expected the clock reset, perhaps not. I'll try your suggestion and if I can get this working reliably for Bluray, I'll likely register.
As an aside (and I can open a different post) do I need to pull done and setup a database for codes and if yes, as there a good blog post or source you'd recommend to follow?
MakeMKV doesn't rely on a database of codes - that's libaacs, if I remember correctly, which MakeMKV can act as a replacement for.
MakeMKV has its own AACS key, which sometimes gets locked out by manufacturers, so it is replaced periodically.
Still having strangeness when trying to rip a bluray (same title as above)...
If I follow the typical straightforward steps: select drive source, click arrow to write to file... I get:
Many files written to my directory (desktop): Copy complete. 10 titles saved, 1 failed.
And of course a failure where it counts... Error text below...
Is the process for bluray different? From all I've read online, it should be same.
Debug logging enabled, log will be saved as /Users/larryebaum/MakeMKV_log.txt
File 00052.mpls was added as title #0
Title #00046.mpls has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00048.mpls was added as title #1
File 00049.mpls was added as title #2
Title #00000.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #3
Title #00019.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.m2ts was added as title #4
File 00027.m2ts was added as title #5
File 00028.m2ts was added as title #6
File 00029.m2ts was added as title #7
File 00030.m2ts was added as title #8
File 00031.m2ts was added as title #9
Title #00032.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00033.m2ts was added as title #10
Title #00034.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 11 titles into directory /Users/larryebaum/Desktop
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '10749345792'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '10749603840'
DEBUG: Code 0 at .QtD%vG:.%AD:?$7B(v?:121263038
DEBUG: Code 0 at xt4O,5U0fm%={9Tq|B8J:121262302
DEBUG: Code 0 at .QtD%vG:.%AD:?$7B(v?:213130559
DEBUG: Code 5248830 at .QtD%vG:.%AD:?$7B(v?:29393286
DEBUG: Code 0 at #qrI[{R4/$Wd92]w[m5zF:29398967
Failed to save title 0 to file /Users/larryebaum/Desktop/title00.mkv
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
It's straight-forward until hardware gets in the way:
The drive says it can't read part of the file. Simple things are cleaning the disk. If that doesn't help and it's a new disk, exchanging for a replacement is an option.Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '10749345792'
Thanks... as to why it creates a separate file for every title? A non bluray it produces a single mkv file... Yea, I know i can select a single title or just toss the ones I don't need, but i'm more curious why the different behavior...
Not sure I understand the question... MakeMKV will make a file for each title on the disk in "write MKV" mode. Not all disks separate episodes into single titles, though.
For example, the anime series Bleach usually has three titles per disk - one with 6 episodes in it, and two short "extras". Some series that are released on both DVD and BD can use a different layout on each... 4-7 episodes in one file on the DVD, and 8 or 9 files with one episode each on the BD, in the same package.
What you get is dependent upon what was put on the disk by the author.
