blu ray with 3 titles, same size.. which is the correct one
MacJollyRoger
Post by MacJollyRoger »
hi,
some blu rays have more than one title, with the same size, and the same time. is there something to know about it?
in this case i used the first one.. seems ok.
Re: blu ray with 3 titles, same size.. which is the correct
Disney likes to put 3 "copies" on disks, with different language choices. For disks sold in north America, those choices are usually 800 (English), 801 and 802 (can't remember which is French and which is Spanish). The TITLES and CREDITS are usually the only parts that are different between them. All will have the same audio and subtitle choices, but the video is different in those places.
Of course, the language choices vary by market, but you can tell which is correct for YOU by watching the titles. Are they in your language? That's probably the one you want.
MacJollyRoger
ah, thanks a lot... yes i choose my language, was also the same. its good to know, its not a BD crypt crap ;-)
