I cannot find a solution to this problem on my CentOS 7 install. I can proceed with the make and then sudo make install, but upon launching MakeMKV, I get an error "Application Failed to Initialize"
Any ideas for a solution?
PKG_CONFIG_PATH=/tmp/ffmpeg/lib/pkgconfig ./configure
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for -objcopy... no
checking for objcopy... objcopy
checking for -ld... no
checking for ld... ld
checking for a BSD-compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for compress2 in -lz... yes
checking openssl/opensslconf.h usability... yes
checking openssl/opensslconf.h presence... yes
checking for openssl/opensslconf.h... yes
checking for AES_encrypt in -lcrypto... yes
checking expat.h usability... yes
checking expat.h presence... yes
checking for expat.h... yes
checking for XML_ParserCreate in -lexpat... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for ffmpeg... yes
checking whether LIBAVCODEC_VERSION_MAJOR is declared... yes
checking LIBAVCODEC_VERSION_MAJOR... failed
configure: error: in `/home/bher/Downloads/makemkv-oss-1.9.5':
configure: error: LIBAVCODEC_VERSION_MAJOR is not known at compile time in libavcodec.h
See `config.log' for more details
						CentOS 7 LIBAVCODEC_VERSION_MAJOR is not known
Re: CentOS 7 LIBAVCODEC_VERSION_MAJOR is not known
I just way building makemkv today on Centos 7. I saw this error when I was using fdk-aac with ffmpeg. The ffmpeg test doesn't find the fdk-aac library, when it's shared (and probably can't use it if it could). The only way to tell if you have the same error as me is digging through config.log
I cleaned all my trees (totally deleted), ffmpeg seems very keen to try and used the shared lib version of fdk-aac, so there needs to be no trace of it.
How I got this to work, if you have the same error as me.
Hope this helps you in some way
cd /home/simpz/Download
mkdir makemkvbuild
cd makemkvbuild
Untarring an ffmpeg source from:
http://ffmpeg.org/download.html
Sources came out at ffmpeg-2.8 under /home/simpz/Download/makemkvbuild
mkdir ffmpeg
FDK-AAC
Downloaded from https://github.com/mstorsjo/fdk-aac/tarball/master
wget -O fdk-aac.tar.gz https://github.com/mstorsjo/fdk-aac/tarball/master
tar xvf fdk-aac-0.1.0.tar.gz
cd fdk-aac-0.1.0/
autoreconf -fiv
./configure --prefix=/home/simpz/Download/makemkvbuild/ffmpeg --disable-shared --with-pic
make
make install
FFMPEG
cd ../ffmpeg-2.8
PKG_CONFIG_PATH=/home/simpz/Download/makemkvbuild/ffmpeg/lib/pkgconfig ./configure --pkg-config-flags="--static" --prefix=/home/simpz/Download/makemkvbuild/ffmpeg --enable-static --disable-shared --enable-pic --disable-yasm --enable-libfdk-aac
make
make install
My configure line for makemkv-oss compile was then just (I wanted it all to end up in /usr/local):
PKG_CONFIG_PATH=/home/simpz/Download/makemkvbuild/ffmpeg/lib/pkgconfig ./configure --prefix=/usr/local
Bingo, worked like a charm! Thanks!
						simpz wrote:I just way building makemkv today on Centos 7. I saw this error when I was using fdk-aac with ffmpeg. The ffmpeg test doesn't find the fdk-aac library, when it's shared (and probably can't use it if it could). The only way to tell if you have the same error as me is digging through config.log
Hope this helps you in some wayCode: Select all
cd /home/simpz/Download mkdir makemkvbuild cd makemkvbuild Untarring an ffmpeg source from: http://ffmpeg.org/download.html Sources came out at ffmpeg-2.8 under /home/simpz/Download/makemkvbuild mkdir ffmpeg FDK-AAC ======= Downloaded from https://github.com/mstorsjo/fdk-aac/tarball/master wget -O fdk-aac.tar.gz https://github.com/mstorsjo/fdk-aac/tarball/master tar xvf fdk-aac-0.1.0.tar.gz cd fdk-aac-0.1.0/ autoreconf -fiv ./configure --prefix=/home/simpz/Download/makemkvbuild/ffmpeg --disable-shared --with-pic make make install FFMPEG ====== cd ../ffmpeg-2.8 PKG_CONFIG_PATH=/home/simpz/Download/makemkvbuild/ffmpeg/lib/pkgconfig ./configure --pkg-config-flags="--static" --prefix=/home/simpz/Download/makemkvbuild/ffmpeg --enable-static --disable-shared --enable-pic --disable-yasm --enable-libfdk-aac make make install My configure line for makemkv-oss compile was then just (I wanted it all to end up in /usr/local): PKG_CONFIG_PATH=/home/simpz/Download/makemkvbuild/ffmpeg/lib/pkgconfig ./configure --prefix=/usr/local
