Not recognising chapers
Chilipalmer
#1 Post by Chilipalmer » Wed Mar 24, 2010 10:32 pm
I am trying to rip my copies of the good life, but the chapters are not being identified - any ideas?
setarip_old
Re: Not recognising chapers
#2 Post by setarip_old » Wed Mar 24, 2010 11:23 pm
Hi!
What version number of MakeMKV are you using?
Chilipalmer
#3 Post by Chilipalmer » Wed Mar 24, 2010 11:35 pm
The new one i loaded it today 1.5.2 64bit as i have win 7 also the inbetweeners will make MKV crash
#4 Post by mike admin » Thu Mar 25, 2010 8:32 am
Are you trying to open DVD or blu-ray?
Do you see chapters in MakeMKV title selection tree view?
What player do you use for playback?
Chilipalmer
#5 Post by Chilipalmer » Thu Mar 25, 2010 7:12 pm
Hi
Its "The Good Life" a series from the BBC late 70's its DVD box set The DVD takes a long time to do the first part and it then shows one file no tree
With Faulty Towers it showed a tree so i un-ticked the subtitles and all went well
i am using windows media player as play back and i use XBMC to test as well
I have ripped about 50 DVD's and up to now only the above and the inbetweeners have had problems
I need wall space as wife is getting very upset at the growing collection LOL
Many thanks for you kind attention and the program is sweet and simple thanks
setarip_old
#6 Post by setarip_old » Thu Mar 25, 2010 9:29 pm
1) Try cleaning the DVD
2) Again, what player do you use for playback?
3) If you play the ORIGINAL DVD under the same player, does it play properly, does it have/can you access chapters?
Chilipalmer
#7 Post by Chilipalmer » Thu Mar 25, 2010 10:03 pm
1 The DVD is clean
2 As above answer
3 Yes if i play the DVD using Media Player on Window 7 it has chapters and play all option
#8 Post by mike admin » Sat Mar 27, 2010 9:56 am
Chilipalmer wrote:Hi
Does it show any chapters? Please submit the log and IFO files for both discs per instructions at http://www.makemkv.com/faq/item/8/catid/6
