I bought Metro Manila from my local movie shop having trouble trying to make a 1:1 copy of it to my PC
Error log:
Debug log started at Thu Sep 17 02:51:34 2015 , written by MakeMKV v1.9.5 linux(x64-release)
001005:0000 MakeMKV v1.9.5 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/hippo/MakeMKV_log.txt
005072:0000 Backing up disc into folder "/media/hippo/WD Green 4TB/Metro"
005050:0000 Evaluation version, 18 day(s) out of 30 remaining
DEBUG: Code 2147483648 at }:B52@yN=rZuwOX4:121265315
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=4v9V3kQJEE3AcCI1Vb+SBqCB50zCcVTtin38TBtOwSvWY1WIxraYze/cZ3Ox+oY49wwlcoM4xsBLPn3IPivyLTen14x4FKOxMq8wT8B32VMdYtBeD0fXtOWvUtdIDZ6YlvrA87oHT6UQ1u6w2XNYYRxSeDjB0JmnRw==
DCE=Oz73JS2y0d2E6c8ii3tbUwFOF9WxtuvsNE7VCnVBToB7CmoOQmOraoNH1NVq8+ZLEQeoOIRXUb4+kuZ6/gxzrwmklnPmnxEc1pqIQJe0jqAVF9KmT1Qk+pkYJOmD6dIqv2Jrxruwfuv7oqm70I1mQjraeeEac2ru1Q==
001003:0020 DEBUG: Code 0 at CL89~h>+zG29!zmMo:}4/:(:213130122
001003:0020 DEBUG: Code 1073741829 at R-71:[z.s)cQ\-0l:29393953
001003:0020 DEBUG: Code 100864261 at #:**uOESe}i"7dCU:121269731
001003:0020 DEBUG: Code 2044 at Ezu1Bx+|jf'=RrLk:213138770
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1592522752'
001003:0020 DEBUG: Code 0 at PYe{sMvalzEnjkun 1c:29398070
001003:0020 DEBUG: Code 0 at I2u|l7!uC?Z#f9;|K U*:121265108
005069:0080 Backup failed
005080:0204 Backup failed.
Disc info:
OS device name: /dev/sr0
Manufacturer: TSSTcorp
Product: BDDVDW SE-506CB
Revision: TS02
Serial number: S15E6YKG3009ER
Bus encryption flags: 1F
Highest AACS version: 48
Disc Information
Label: METRO MANILA
Timestamp: 2014-08-07 09:41:54
Data capacity: 22.31 Gb
Disc type: BD-ROM
Number of layers: 1
Any solutions?
Thank you
Metro Manila Stuck at 90+%
Re: Metro Manila Stuck at 90+%
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1592522752'MakeMKV Frequently Asked Questions
hippo778
Still no luckWoodstock wrote:Your drive can't read part of the disk. If cleaning it does not help, it is possible that increasing the number of retries might. That's Preferences->IO, and usually set to 5.Code: Select all
Anything is possible. External drives, though, usually have issues when the speed gets too high, and they run out of power... then you get connection errors. That doesn't seem to be the case here.
If you have another drive available, attempt the rip with it. Every drive is ever so slightly different in laser alignment, and some can see good data where others see errors. I have 4 different BD drives available, and I have some disks that simply won't work in 3 of the 4. There are also 2 DVD drives, because some DVDs don't work with blue lasers.
hippo778
Alright! Thank youWoodstock wrote:Anything is possible. External drives, though, usually have issues when the speed gets too high, and they run out of power... then you get connection errors. That doesn't seem to be the case here.
