Version 1.9.5 installer cannot install
botakwts
Post by botakwts »
I downloaded the latest version 1.9.5 and ran the installer on my Windows 7 64 Ultimate. Even if the target subdirectory is totally empty, it still complaints - about "non empty subdirectory". The previous version 1.9.4 installs - without any problems. Thanks.
Yugatha
Re: Version 1.9.5 installer cannot install
Post by Yugatha »
I believe this ended up being a bug. Delete the directory, and it should install properly. Or download the 1.9.7 installer from the main page.
botakwts
Post by botakwts »
Thank you. You are right. Even the 1.9.7 (latest) won't install in an empty subdirectory. I have to delete the entire subdirectory - then it works.
Very strange - my v1.9.5 install was properly overwritten by 1.9.7, but I allowed the uninstall to complete before continuing the install. The directory was NOT empty when the installer continued - my configuration and profile files were still there.
botakwts
Post by botakwts »
Very strange - I have no idea what causes the problem on my Windows 7 Ultimate either. But I solved the problem - that's the most important.
