Suddenly started crashing
dolphineus
#1 Post by dolphineus » Sat Sep 12, 2015 1:26 pm
Been using MakeMKV 1.9.5 for a couple months on Windows 7 without issue.
Went to use it yesterday and it crashed as soon as I started it. It has done nothing but crash since then.
I rebooted and it still crashed. Disabled the antivirus, still crashed. Uninstalled and reinstalled, still crashes. Downloaded fresh copy from makemkv.com, uninstalled and reinstalled. Still crashing.
Can anyone help?
Problem Event Name: APPCRASH
Application Name: makemkvcon64.exe
Application Version: 0.0.0.0
Application Timestamp: 55b55755
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.18798
Fault Module Timestamp: 5507b864
Exception Code: c0000005
Exception Offset: 000000000004e128
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: 3a9b
Additional Information 2: 3a9bd2f3680d96275b17b25fa5124f79
Additional Information 3: 7249
Additional Information 4: 724993b4844351df2dca2bf679502e82
halian
Re: Suddenly started crashing
#2 Post by halian » Mon Sep 14, 2015 9:02 pm
I'm having exactly the same problem - and have posted in a different thread (you can find it pretty easily). Someone has suggested there that it might relate to certain Windows updates.
I've installed it on three Windows 7 machines - all with the same problem. They all, also, run Bit Defender. Following advice elsewhere (in this forum) I've added some additional firewall rules - they have not helped. I'm tempted to remove Bit Defender as I suspect it interferes with a lot of stuff.
My crash details are somewhat similar to yours (the precise fault module version is slightly different):-
Fault Module Version: 6.1.7601.18933
Fault Module Timestamp: 55a6a196
Exception Offset: 000000000004df08
Locale ID: 2057
dolphineus
#3 Post by dolphineus » Fri Sep 18, 2015 3:46 pm
The problem is BitDefender Free. For some reason it kills MakeMKV.
Uninstall BitDefender Free, problem went away.
Now using Avira. Shame, I liked BitDefender's minimalist approach.
#4 Post by Woodstock » Sat Sep 19, 2015 3:03 am
At least two antivirus products have started to give generic "could be malicious so we're stopping it" problems with MakeMKV. Searching for the information on what the warning meant pointed to activity like contacting outside systems. When MakeMKV checks for new versions or SVQ files, it contacts this website....
IP Results
Source: makemkv.com
IP: 5.178.87.118
That alone might be enough to cause this.
