"Scsi error", "KEY NOT ESTABLISHED", "Can't read AACS VID"
HaselnuesseTo
Post by HaselnuesseTo » Fri Sep 11, 2015 1:14 pm
Hey! My problem is the following.. I can't rip any BluRay:
MakeMKV v1.9.5 linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..0800024C0 to device 'SG:dev_11:0'
Highest AACS version is v31 , MKB saved as /home/brace/.MakeMKV/MKB_v31_The_Dark_Knight_Rises.tgz
Re: "Scsi error", "KEY NOT ESTABLISHED", "Can't read AACS VI
Post by Woodstock » Fri Sep 11, 2015 1:48 pm
This usually indicates that MakeMKV was not allowed to communicate with the drive to exchange the AACS key information. V1.9.5 has the ability to deal with AACS versions up through 56, but it can only do that if it's allowed to talk to the drive.
Is the user ID being used to run MakeMKV a member of root's group, or otherwise assigned the ability to directly talk to the hardware?
HaselnuesseTo
Post by HaselnuesseTo » Sun Sep 13, 2015 3:13 pm
No.. It changed nothing. I tried to run makemkv as root:
brace@brace-6:~$ id
uid=1000(brace) gid=1000(brace) groups=1000(brace),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),108(lpadmin),123(sambashare)
brace@brace-6:~$ sudo adduser brace root
Adding user `brace' to group `root' ...
Adding user brace to group root
Done.
brace@brace-6:~$ exec su -l
brace@brace-6:~$ id
uid=1000(brace) gid=1000(brace) groups=1000(brace),0(root),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),108(lpadmin),123(sambashare)
brace@brace-6:~$ sudo makemkv
kwagoner
Post by kwagoner » Wed Sep 16, 2015 3:59 am
I'm running into exactly the same error condition:
...[may proceeding lines]...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01CFFB0984C40B7BFAC75B711A3FC3AEFC1 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Highest AACS version is v54 , MKB saved as C:\Users\Kevin/.MakeMKV/MKB_v54_INSURGENT.tgz
I have not found a workaround. Any suggestions?
Post by mike admin » Sat Sep 26, 2015 12:37 pm
Can you think of a recently released blu-ray disc, that you've inserted into the drive and then it triggered this error for all discs?
DaveM77
Post by DaveM77 » Thu Oct 01, 2015 6:02 pm
I got this error with Focus and am now getting it with Unbroken too.
Submitted reports on both by clicking the link.
Muzzy
Post by Muzzy » Mon Oct 19, 2015 3:10 am
I too am getting this error on the Lost in Space BluRay Discs
MakeMKV v1.9.7 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..084002400 to device 'SPTI:\Device\CdRom0'
Both disc and drive require bus encryption, but the bus key is not known.
Downloading latest SVQ(s) to C:\Users\MrMuz_000/.MakeMKV ...
Loaded 34 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using disc-specific SVQ from C:\Users\MrMuz_000/.MakeMKV/00000155.svq
BD+ code processed, got 1 FUT(s) for 36 clip(s)
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Hash check failed for file 02362.m2ts at offset 190464, file is corrupt.
Hash check failed for file 02362.m2ts at offset 387072, file is corrupt.
Hash check failed for file 02362.m2ts at offset 583680, file is corrupt.
Hash check failed for file 02362.m2ts at offset 780288, file is corrupt.
Hash check failed for file 02362.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 02362.m2ts.
Muzzy
Post by Muzzy » Mon Oct 19, 2015 4:39 am
OK I refrence to my previous Post Apparently Windows 10 Is still preventing communication from the program to the drive. I reverted back to Windows 8.1 and Everything is Ripping Perfectly...
wytpages
Re: "Scsi error", "KEY NOT ESTABLISHED", "Can't read AACS VID"
Post by wytpages » Tue Dec 21, 2021 6:28 am
Same issue but on a Mac. Been using Makemkv for years never had this issue before.
