many titled blurays?
archer75
Post by archer75 »
Those bluray discs that seem to have a million titles on them. How do you tell which is the correct one to rip? What programs are you using?
Re: many titled blurays?
MakeMKV can handle ripping the disk, so long as you know which title is correct. And "which title" varies with the source of the disk you bought. That is, the copy of "Expendables 3" from Target has a different "correct title" than the copy from Walmart or Amazon.
There are ways to find the "right title" yourself, but they're getting more complex each month. If you are interested, a new member posted this:
http://makemkv.com/forum2/viewtopic.php ... 582#p41448
Otherwise, searching for the title and "right playlist" can usually find a discussion on which playlist is right.
