Insurgent retail
GoofeyGuy
Re: Insurgent retail
Anyone have the correct playlist for the Nordic version ?
augerpro
I'm trying to find a reasonably robust yet quick way to figure these sorts of discs out. I'll take a look into the options you mentioned. Thought the PM + PowerDVD had 'em beat!DJRumpy wrote:Some people have BD players that list the files that are opened for each chapter. They also narrow down by play time (many times the lengths all differ). Some also use AnyDVD to get a list of 'valid' MPLS. Sometimes it's a combination of the above. It just takes time and a little help from the community too. If you also have a difficult one, Mike the Admin can also take a look sometimes. It may require that you upload some debugging files though.
eNoize
For those who purchased the 3D Blu-ray Combo Pack, the correct file on the 2D disc is 00407.mpls
DaveK8
Thanks eNoize. I'll try 407 for the 2D disc.
eNoize
whatgoeshere
They have found a way to hide which playlist is the correct one while using monitoring software.
it is altering the name of the playlist in order to obscure which order is correct.
https://forum.slysoft.com/showthread.php?64253-Insurgent&p=412233#post412233-
augerpro
Thanks for the link, looks like people are on it! I swear this is so absurd, commercial pirates will always find a way around this crap, all it does is screw legitimate owners from using their property as they see fit.whatgoeshere wrote:They have found a way to hide which playlist is the correct one while using monitoring software.
it is altering the name of the playlist in order to obscure which order is correct.Code: Select all
Ixion1986
For Nordic Version (DK):
00328.mpls
It works perfectly
00328.mpls
It works perfectly
boxerjake
03-firefly-k64 wrote:510, 509, 506, 502, 504, 508, 505, 511, 501, 507, 503
Amazon retail title 407
I've gotten info from this forum for years. Happy I can finally contribute!
Unfortunatly not for mine ( Walmart canada ) .... on my copy all playlists start with 506 and end with 503,508 , the center beng mixed in different orders .
gereral1
I made 2 videos on how to deal with this exact movie on YouTube. As new protections come out I'll figure a way to overcome them. Type in gereral1 in Google to visit my YouTube channel jackofalltrades and goto home theater playlist. There is 3 videos showing you the 2 types of screen pass that Hollywood is using. Since they are trying to fool us and hiding the mpls I show you how to used the cashed mpls to find the original movies disk mpls. Also have a video accessed inside mpls finder software developed by Rotty dog and me to automate this stupid screen pass crap.
buckwyld
Thanks. This is also the right one for the 3D Blu Ray combo steelbook from Best Buy.eNoize wrote:For those who purchased the 3D Blu-ray Combo Pack, the correct file on the 2D disc is 00407.mpls
BlenderRookie
This was the correct one for me as well. Mine was either a Best buy or Amazon purchase.critical wrote: Fri Aug 07, 2015 5:02 am I have the single disc retail version from Costco.
Would like to confirm that the correct segment for me was also 510,509,506,502,504,508,505,511,501,507,503
The only difference is that the segment was located in title 83.
I compared the rip and the disc, taking note of chapter length and scenes, everything matched up perfectly.
sctygen
EDIT -> this is the one that worked for me.
Title information
Source file name: 00286.mpls
Duration: 1:59:00
Chapters count: 16
Segment count: 20
Segment map: 518,509,519,503,511,516,513,501,517,514,508,515,520,506,502,504,505,510,512,507
File name: Insurgent_t80.mkv
Title information
Duration: 1:59:00
Chapters count: 16
Segment count: 20
SneezyDwarf
Thanks sctygen!
I just wanted to confirm that this worked for me as well. Amazon Blu Ray purchased in 2021.
sctygen wrote: Sat Nov 27, 2021 7:49 pm EDIT -> this is the one that worked for me.
Title information
Duration: 1:59:00
Chapters count: 16
Segment count: 20
Balefire
I got the 3 disk pack on Amazon in 2022, none of the above segment orders worked for me. I used the instructions on this post viewtopic.php?t=16251
to find the segment order, and got
"518,519,511,503,509,516,513,501,520,517,508,515,514,506,502,505,504,510,512,507"
which was title 235 on my disc.
