Far from the Madding Crowd, AACS v50, BD+ v2015.5
nicholfd
#1 Post by nicholfd » Tue Sep 01, 2015 11:52 pm
I have "Far from the Madding Crowd". AACS info is: AACS v50, BD+ v2015.5. After scanning it the output is listed at the bottom. There was a pop-up message, "BD+ code processed but no FUTs were obtained, errors may follow". I tried attaching the dump file (8.8MB), but the the BB system seems to puke on it.
Because of the pop-up message, I'm making a complete disc backup, and leaving it encrypted.
Should I be concerned with this?
Thanks,
Frank
MakeMKV v1.9.5 darwin(x86-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.00d" opened in OS access mode.
Downloading latest SVQ(s) to /net/server/Data/Documentation/MakeMKV Data ...
Loaded 422 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /net/server/Data/Documentation/MakeMKV Data/dump_Far_from_the_Madding_Crowd_D52B0D73DB816DEF.tgz
Title #00001.mpls has length of 137 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
File 00850.mpls was added as title #0
Title 00800.mpls is equal to title 00850.mpls and was skipped
Title #00476.mpls has length of 1074 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00477.mpls(3) has length of 236 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00652.m2ts has length of 60 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00653.m2ts has length of 98 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
File 00660.m2ts was added as title #2
Title #00661.m2ts has length of 137 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
nicholfd
Re: Far from the Madding Crowd, AACS v50, BD+ v2015.5
#2 Post by nicholfd » Wed Sep 02, 2015 12:07 am
Dump file was sent to "svq@makemkv.com".
It's 8.8MB...
#3 Post by Woodstock » Wed Sep 02, 2015 1:09 am
Don't worry - 8.8 MB should get through to Mike.
As for the backup... if your player software understands BD data and can decode the BD+ programming, it may work.
nicholfd
#4 Post by nicholfd » Wed Sep 02, 2015 1:34 am
Woodstock - Thanks for the reply.
I run MakeMKV on a Mac & use XBMC as my media player. Ultimately I just want an MKV for use with XBMC.
Thanks,
Frank
#5 Post by mike admin » Wed Sep 02, 2015 10:38 am
This is a new version of BD+ . We are working on it, the ETA is unknown :(
alahen
#6 Post by alahen » Wed Sep 02, 2015 12:01 pm
I have had the exact same error with this blu-ray.
I tried ignoring it but when I played back the resultant mkv file the picture was distorted.
Is there anything that can be done, or do I need to wait for a fix?
Thanks.
#7 Post by Woodstock » Wed Sep 02, 2015 1:42 pm
Because of the nature of BD+, it's got to wait for Mike to create an SVQ for it.
You can find more information about it here: http://www.makemkv.com/svq/
alahen
#8 Post by alahen » Wed Sep 02, 2015 2:00 pm
Thanks for your reply.
I have emailed in my dump file as well. Hopefully it will be sorted soon.
Cheers.
JDEntwistle
#9 Post by JDEntwistle » Wed Sep 02, 2015 4:24 pm
I tried making a BU of the HD DVD today, September 2, 2015, and still get a lot of tiling on the final video.
kslayer
#10 Post by kslayer » Thu Sep 17, 2015 4:35 am
Just got this exact same error. Any updates to when an update will be available?
nicholfd
#11 Post by nicholfd » Tue Oct 06, 2015 8:20 pm
Bump - Has this title been fixed yet?
Thanks,
Frank
#12 Post by mike admin » Sun Oct 11, 2015 11:30 am
Fixed for some disc versions - for ones we've got the dumps for. If your disc still doesn't work, then please send the dump as usual. Make sure the dump is created by 1.9.6 or 1.9.7 .
henryf
#13 Post by henryf » Mon Dec 07, 2015 8:51 am
I'm encountering the same problems with the German version of "Far from the Madding Crowd". I've sent a dump file to svq@makemkv.com. I'm running the most recent version of makemkv (1.9.7) and the program has obviously downloaded all recent SVQs but none of the seem to apply here. I'm hoping for a new SVQ file. Thanks a lot in advance!
