Fast and Furious 7
mgrobins
Fast and Furious 7
#1 Post by mgrobins » Tue Sep 01, 2015 9:56 am
this one is coming up with illegal SCSI errors and won't complete.
Saving 1 titles into directory H:/Movies
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1565589504'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1566179328'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1566504960'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1568403456'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1568735232'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1569060864'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1569650688'
Failed to save title 1 to file H:/Movies/Fast_and_Furious_7_t01.mkv
0 titles saved, 1 failed
Any suggestions?
Re: Fast and Furious 7
#2 Post by Woodstock » Tue Sep 01, 2015 2:36 pm
Were there errors during the scan phase, or just when you selected Save?
mgrobins
#3 Post by mgrobins » Tue Sep 01, 2015 9:00 pm
I think it was when it was saving.
I would hit the button to start the scan, which it would do and then those errors arose at the end.
I tried AnyDVD HD as well and had a read error.
There are 2 movie tracks and I have it for each of them.
I cannot see anything other than a very light scratch at the outer edge of the disc (circumferential not radial).
#4 Post by Woodstock » Wed Sep 02, 2015 1:07 am
Bluray, more so than DVD, is sensitive to ANYTHING on the surface. But, the error for a dirty disk usually says it's unreadable, not "illegal". Where that can come up is if there was an error reading the directory information, where there is a problem reading the information needed for telling the drive it's OK to decrypt things.
Make sure you have debug logging turned on, and re-try the rip. That will give more information.
mgrobins
#5 Post by mgrobins » Wed Sep 02, 2015 5:10 am
Log now states:
Saving 1 titles into directory H:/Movies/Fast and Furious 7 (HD)
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1592064000'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1592389632'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1592653824'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1592979456'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1593311232'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/01535.m2ts' at offset '1593636864'
DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:121263038
DEBUG: Code 0 at =7aE'iYVX@qJ'A7BtXsq:121262302
DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:213130559
DEBUG: Code 778143 at iaWwv[BA)Fj)ozu9 TD1:29393286
DEBUG: Code 0 at [8elkj;bRJh6^aE%w"Tz':29398967
Failed to save title 0 to file H:/Movies/Fast and Furious 7 (HD)/Fast_and_Furious_7_t00.mkv
iMactouch
#6 Post by iMactouch » Mon Oct 19, 2015 1:19 pm
I am getting this error when ripping this Blu-Ray:
AV sync issue in stream 1 at 0:12:16.736 with duration of 10.458ms : encountered overlapping frame, audio skew is +10.666ms
AV sync issue in stream 1 at 0:12:16.746 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +0ms
AV sync issue in stream 1 at 0:13:14.126 with duration of 6.666ms : encountered overlapping frame, audio skew is +6.666ms
AV sync issue in stream 1 at 0:27:19.095 with duration of 1.541ms : encountered overlapping frame, audio skew is +8.208ms
AV sync issue in stream 1 at 0:28:35.171 with duration of 9.333ms : encountered overlapping frame, audio skew is +17.541ms
AV sync issue in stream 1 at 0:28:35.189 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +6.875ms
AV sync issue in stream 1 at 0:29:56.628 with duration of 4.958ms : encountered overlapping frame, audio skew is +11.833ms
AV sync issue in stream 1 at 0:29:56.640 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +1.166ms
AV sync issue in stream 1 at 0:30:17.816 with duration of 6.833ms : encountered overlapping frame, audio skew is +8ms
AV sync issue in stream 1 at 0:33:23.876 with duration of 8.458ms : encountered overlapping frame, audio skew is +16.458ms
AV sync issue in stream 1 at 0:33:23.893 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +5.791ms
AV sync issue in stream 1 at 0:33:46.566 with duration of 9.333ms : encountered overlapping frame, audio skew is +15.125ms
AV sync issue in stream 1 at 0:33:46.581 with duration of 10.666ms : 1 frame(s) dropped to reduce audio skew to +4.458ms
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/01532.m2ts' bei Offset '8161916928'
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/01532.m2ts' bei Offset '8162242560'
DEBUG: Code 0 at VL'VrJz@G6>mQN0z#s9":121263038
DEBUG: Code 0 at !5#0q]?KmM3*0rA RPM):121262302
DEBUG: Code 0 at VL'VrJz@G6>mQN0z#s9":213130559
DEBUG: Code 3985470 at VL'VrJz@G6>mQN0z#s9":29393286
DEBUG: Code 0 at "Bi_IjpT/Uy'`]]QUTb5i:29398967
#7 Post by Woodstock » Mon Oct 19, 2015 6:40 pm
Your drive says it can't read parts of the disk. What happens if you clean the disk?
iMactouch
#8 Post by iMactouch » Mon Oct 19, 2015 8:29 pm
Woodstock wrote:Your drive says it can't read parts of the disk. What happens if you clean the disk?
The disk is clean. I will try to watch it with my normal Blu-Ray player in the next days, to see if there is really something wrong. I had other Blu-Rays with fingerprints on it and a few scratches, that doesn't make any problems. Strange.
iMactouch
#9 Post by iMactouch » Wed Oct 21, 2015 3:52 pm
I tried it on a normal Sony Blu-Ray player and there are no problems.
Only with my external Pioneer BDR-XD05 attached to my Mac I have these problems.
Now I am trying a complete Backup.
astb41
#10 Post by astb41 » Wed Nov 04, 2015 6:25 pm
I had this same problem. I un-installed and re-installed the MakeMKV program and now it works.
