Error opening disc Boardwalk Empire
Isaksson
Post by Isaksson » Thu Aug 13, 2015 2:30 pm
Hello.
I have problem opening the disc for the series Boardwalk Empire.
Here is the debug Log
Debug log started at Thu Aug 13 14:12:12 2015 , written by MakeMKV v1.9.5 win(x64-release)
001005:0000 MakeMKV v1.9.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\kristoffer/MakeMKV_log.txt
Title skip vts=1 pgcn=1 hash=37BC908E9595DBD7
Title skip vts=1 pgcn=2 hash=0193094DF3A889E0
Title skip vts=1 pgcn=4 hash=B89EBB583244E76B
003025:0000 Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=1 hash=0FE1D38210827D77
Title skip vts=3 pgcn=2 hash=67446E8364C538C0
003025:0000 Title #10 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at xcjFdowO/6wQKKCOz7mxc0nG:0
Application exited at Thu Aug 13 14:12:40 2015
I have tried to open it in Handbreak and it gives me 4 titles, 1,2,4 and 8. Title 1 and 2 is the "correct" ones.
Re: Error opening disc Boardwalk Empire
Post by Woodstock » Thu Aug 13, 2015 2:45 pm
This is the issue, I think:
Mike will have to translate what that code means, but MakeMKV wasn't able to complete building its description of the disk's contents.
Isaksson
Post by Isaksson » Thu Aug 13, 2015 3:31 pm
Thanks for the reply, do you think that this issue get resolved or do i have to make this series with handbreak (dont like that)?
Post by Woodstock » Thu Aug 13, 2015 10:31 pm
I can't say for sure. Only Mike can, and he's probably going to want more information from you. Start with the information requested in the FAQ link in my signature, and email the requested files to support@makemkv.com so that he gets them.
A bigger question would be, CAN you rip this disk using Handbrake? Or do you get errors with it? Handbrake is FAR more sensitive to disk errors than MakeMKV.
Why? Because Handbrake isn't intended to rip copy-protected (encrypted) disks - it can only do so if you install a 3rd-party library that enables handling CP disks, and the libraries that it will work with are not very aggressive when it comes to dealing with imperfection.
If an error occurs in a HB rip, the resulting file is just closed at the point it was at. An error at 5 minutes into a 3 hour movie will give you a perfectly good 5 minute output file.
To be honest, a fingerprint or a scratch in the wrong place can give you the issue you're seeing. MakeMKV does a more detailed scan of the disk directory structure than Handbrake does, which means HB can think the disk is fine, even when it isn't. I had a disk just today that seemed to be ripping slow, with no errors. I got tired of it taking 45 minutes to rip a single title, so I pulled it and cleaned/waxed it. The second attempt at ripping sped up considerably!
Isaksson
Post by Isaksson » Fri Aug 14, 2015 7:33 am
Thanks for the help.
I have now emailed and included the log and *.ifo files.
And yes, it is working with Handbreak, tried yesterday with the first disc and there was no error.
Post by mike admin » Thu Aug 27, 2015 4:56 pm
This is a bug. The workaround is to note the proper title number in any DVD player, and use manual mode /manualdvd/ to open the disc.
