Following pop-up appears when trying to install update to D:\Program Files (x86)\MakeMKV\
which is where MakeMKV has always resided.
"MakeMKV installer
The selected installation directory is not empty. Please choose another installation directory."
MakeMKV v1.9.5 Setup reports:
Space required: 114.0MB
Space available: 301.7GB
After installing several MakeMKV updates in this location, this is the first time this has happened.
1.9.5 Windows Installation Error on Windows 8
robertsd
Yugatha
Re: 1.9.5 Windows Installation Error on Windows 8
Please try uninstalling MakeMKV completely from the computer, then ensure the installation folder is deleted. Then, try installing it again as administrator (right-click -> Run as Administrator). This *should* fix the issue.
robertsd
That did it. Thanks so much!
