can't build makemkv v 1.9.5 on linux mint 17
nohelp54
Post by nohelp54 »
when I try to build makemkv i get the following error.
DHAVE_BUILDINFO_H -Itmp -I/usr/local/include \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -pthread -L/usr/local/lib -lavcodec -lxcb-xfixes -lxcb-render -lxcb-shape -lxcb -lX11 -lz -lswresample -lavutil -lm -lm -lrt
/usr/bin/ld: /usr/local/lib/libavcodec.a(allcodecs.o): relocation R_X86_64_32 against `ff_a64multi_encoder' can not be used when making a shared object; recompile with -fPIC
/usr/local/lib/libavcodec.a: error adding symbols: Bad value
collect2: error: ld returned 1 exit status
make: *** [out/libmakemkv.so.1.full] Error 1
Building makemkv oss for 1.9.5 failed - aborting
****** Certain systems may require a compiler switch change ******
Please edit /tmp//makefile.linux and change:
grep: invalid option -- 'p'
Usage: grep [OPTION]... PATTERN [FILE]...
Try 'grep --help' for more information.
to:
-lQtDBus -lpthread -lz -lrt
fairoaks
Re: can't build makemkv v 1.9.5 on linux mint 17
Post by fairoaks »
Much easier to do this:
sudo add-apt-repository ppa:heyarje/makemkv-beta
sudo apt-get update
sudo apt-get install makemkv-bin makemkv-oss
nohelp54
Post by nohelp54 »
THANK YOU, THAT WORKED PERFECTLY :D
