Please Help
I am getting an MakeMKV BETA popup
Copy complete. 0 titles saved, 1 failed
DEBUG: Code 0 at [8elkj;bRJh6^aE%w"Tz':29398967
Failed to save title 0 to file I://The_Spy_Next_Door_t00.mkv
MakeMKV_log
Debug log started at Fri Aug 21 18:18:23 2015 , written by MakeMKV v1.9.5 win(x64-release)
001005:0000 MakeMKV v1.9.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Wayne/MakeMKV_log.txt
DEBUG: Code 2147483648 at ^%89q5[n5PypdO,l:121265315
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=/l9NltErmgeameakW3VvHVX4Jz1XcdwHGxi4ly0BMRyWUJMRUyrdFRlpiFf8kzdXMdNZ5aiZuWN5NgT4JIJE9Ot3Z5olYuDiDa85Gf4MjGxbV8G7HjvBhl4ccBA9xEoffYzRdE3lJO2MhAebHUSNIUcIF1NGhvWK/A==
DCE=GUwf6mrv3bpHH4urvHjbPPeZzqug+Kil5g9Prdzvp3uEl9U6ucdJW0bsSB3x+nkens9os7vKhMfERx4KLO3ASF5YwlRFMJ+m9zh6bsMjZTGFAdtnXtVtc4hHwGtbcOlMXvgRSz0mZFRzd11IRvtpWk0lima7Vqw4Dw==
DISCID=53A0E3B495282960728EB6277C0041FB5DFD772C
003025:0000 Title #00013.mpls has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00004.mpls was added as title #0
003025:0000 Title #00504.mpls(1) has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00035.mpls was added as title #1
003309:0000 Title 00030.mpls is equal to title 00035.mpls and was skipped
003025:0000 Title #00003.mpls has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00153.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00240.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00241.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00242.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00243.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00249.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00311.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00322.m2ts was added as title #2
003307:0000 File 00327.m2ts was added as title #3
003025:0000 Title #00340.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00350.m2ts was added as title #4
003307:0000 File 00351.m2ts was added as title #5
003307:0000 File 00352.m2ts was added as title #6
003025:0000 Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory I:/
001003:0020 DEBUG: Code 3221225628 at 65f*?&E;3`.V2!/4LOphQw({$:121263521
001003:0020 DEBUG: Code 3221225628 at S@|C4YnmLkr|*7E[:29393953
001003:0020 DEBUG: Code 100864261 at 8~1}?:Qb]C~:!]x^:121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00323.m2ts' at offset '2075523072'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00323.m2ts' at offset '2075529216'
001003:0020 DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:121263038
001003:0020 DEBUG: Code 0 at =7aE'iYVX@qJ'A7BtXsq:121262302
001003:0020 DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:213130559
001003:0020 DEBUG: Code 1013442 at iaWwv[BA)Fj)ozu9 TD1:29393286
001003:0020 DEBUG: Code 0 at [8elkj;bRJh6^aE%w"Tz':29398967
005003:0000 Failed to save title 0 to file I://The_Spy_Next_Door_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Fri Aug 21 18:32:15 2015
Error Help
Re: Error Help
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00323.m2ts' at offset '2075523072'I'm thinking disk cleaning - the error is probably a fingerprint.
