Can you tell me how I can find my registration code?
I've rebuilt my computer and now MakeMKV says I am unregistered.
Many thanks
Charles Orr
Registration Code
Re: Registration Code
First, check your email archives for a message from avangate.com; this is the company that sends out the registration codes.
If you don't find that, send a message to support@makemkv.com and Mike will get back to you. Using the same email address as you originally registered with will be helpful, but he can work with you on that.
Charles Orr
Many thanks for that information.
Now sorted.
Charles
Now sorted.
Charles
