Error almost every time, every disc
AaronR650
Post by AaronR650 » Mon Aug 17, 2015 8:15 pm
I'm Ripping the Twilight series for my mother and on a few of the disc it will get to about 60-70% and then will stop or freeze. I put my cursor with in the window and its "loading" no matter how long i leave it, it still loads. Finally when i click the screen it goes grey and the program stops working.
if you need more info ask away.
thank you for your time.
Re: Error almost every time, every disc
Post by Woodstock » Mon Aug 17, 2015 11:16 pm
Follow the instructions in the FAQ link in my signature to turn on debug logging. There may be something in the log that points to what is going on.
Is it JUST this series, or all Bluray disks you try to rip?
AaronR650
Post by AaronR650 » Mon Aug 17, 2015 11:24 pm
ive cleared some space on my ssd so now i have 40GB free. Before i had 1.5GB free. When i looked at taskmanager the SSD drive was 100% in use when i had the save directory on the HD 1TB. I think it rips the data onto the ssd and then moves the data to the HD and there wasnt enough "cache" space on the SSD. Running it again to test that theory will turn on Log when its over or if it fails.
AaronR650
Post by AaronR650 » Tue Aug 18, 2015 12:42 am
so far it stops on every other bluray disc. I have the Log file but dont know what program to open it with... but i cant upload it "Sorry, the board attachment quota has been reached."
AaronR650
Post by AaronR650 » Tue Aug 18, 2015 12:45 am
Woodstock wrote:Follow the instructions in the FAQ link in my signature to turn on debug logging. There may be something in the log that points to what is going on.
i try uploding the zipped log file(.tgz) and nothing
i try uploading the individual files .dat and .ifn but nothing
Post by Woodstock » Tue Aug 18, 2015 12:54 am
The log file is a text file - you can open it with any text editor.
No need to attach files to the board - the log itself can be included in a message by pasting it in, provided it is under about 59K.
jam062307
Post by jam062307 » Thu Aug 20, 2015 1:56 am
I am still experiencing a bunch of scis errors with windows 10. Here is the latest log...
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '4805984256'
DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:121263038
DEBUG: Code 0 at =7aE'iYVX@qJ'A7BtXsq:121262302
DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:213130559
DEBUG: Code 2346672 at iaWwv[BA)Fj)ozu9 TD1:29393286
DEBUG: Code 0 at [8elkj;bRJh6^aE%w"Tz':29398967
Different tries gives errors at different parts of the disc. not sure why. The disc is clean and scratch free.
Post by Woodstock » Thu Aug 20, 2015 1:34 pm
Have you recently blown the dust out of the drive itself?
MakeMKV is limited in what it can do when confronted with read errors. Sometimes, increasing the number of retries can help... That's on the "IO" page of preferences, and defaults to 5.
