makemkv 1.9.5: COPY PROTECTION KEY EXCHANGE FAILURE
axkayavoco
Post by axkayavoco » Sat Aug 15, 2015 4:22 pm
i tried to backup bluray discs with a external firstcom n1154 drive, but it gives nothing but errors.
what can i do ?
OS device name: /dev/sr2
Manufacturer: MATSHITA
Product: BD-MLT UJ260AF
Revision: 1.00
Serial number: WQ00 041229
Highest AACS version: 47
Disc Information
Label: X-Men_Days of Future Past
Timestamp: 2014-08-15 11:21:35
Data capacity: 45.11 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.9.5 linux(x64-release) started
Backing up disc into folder "/data/raid2/video/bluray/backup/X-Men_Days of Future Past"
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..0800024C0 to device 'SG:dev_11:2'
Highest AACS version is v47 , MKB saved as /home/sd/.MakeMKV/MKB_v47_SKY_CAPTAIN.tgz
Backup failed
Re: makemkv 1.9.5: COPY PROTECTION KEY EXCHANGE FAILURE
Post by Woodstock » Sun Aug 16, 2015 1:45 am
Bluray drives require direct communication with the hardware to do the key exchange on Bluray disks. DVDs are less problematic, because the firmware in the drive doesn't do so much of the copy protection. Sometimes the operating system interferes with that direct communication.
Are you running MakeMKV with permissions that allow it to talk to the hardware?
axkayavoco
Post by axkayavoco » Sun Aug 16, 2015 5:53 am
running as root did not help.
debug log follows:
DEBUG: Code 2147483648 at }:B52@yN=rZuwOX4:121265315
DAFD=PAAAADAAAAEABDQkEGwEBAQ==
001003:0020 DEBUG: Code 0 at ;=^B!N2^'WS+Ok%A?:213130582
001003:0020 DEBUG: Code 0 at UR1\pvQo6ha-]&HWL?:29395195
001003:0020 DEBUG: Code 0 at UR1\pvQo6ha-]&HWL?:121262647
001003:0020 DEBUG: Code 1 at UR1\pvQo6ha-]&HWL?:121262647
001003:0020 DEBUG: Code 2 at UR1\pvQo6ha-]&HWL?:121262647
001003:0020 DEBUG: Code 3 at UR1\pvQo6ha-]&HWL?:121262647
001003:0020 DEBUG: Code 4 at UR1\pvQo6ha-]&HWL?:121262647
002004:0000 Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' trat auf während der Übertragung des SCSI-Befehls AD010..0800024C0 zu Laufwerk 'SG:dev_11:2'
DEBUG: Code 0 at ;=^B!N2^'WS+Ok%A?:213130306
001003:0020 DEBUG: Code 0 at UR1\pvQo6ha-]&HWL?:29396345
003306:0000 AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
003341:0000 Highest AACS version is v46 , MKB saved as /root/.MakeMKV/MKB_v46_X-Men_Days_of_Future_Past.tgz
003303:0000 Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
001003:0020 DEBUG: Code 0 at IQ;]wZjaD~+%Y\S&:121264073
001003:0020 DEBUG: Code 0 at PYe{sMvalzEnjkun 1c:29403912
001003:0020 DEBUG: Code 0 at I2u|l7!uC?Z#f9;|K U*:29396851
005069:0080 Backup fehlgeschlagen
005080:0204 Backup fehlgeschlagen.
gellis
Post by gellis » Thu Oct 01, 2015 8:36 am
look in dmesg for the hardware id of the carrier for the drive.
I bought that drive off ebay and it came in a caddy made by initio (no mention on caddy, this is from looking in dmesg).
I found that the initio chip set for usb3 does not work under linux when working with makemkv. I bought a usb -> 13 pin sata cable from ebay and it arrived yesterday. This is usb2, and also made by initio, however it seems to work (i can do makemkvcon list disc:0 - or info disc:0 - can't remember which is correct, I always get them muddled up) . Makemkvcon now exits, however I'm hoping this is some config issue on my side. I'm going to try running makemkv via x server tonight to see if that works.
For more info see my other thread - http://www.makemkv.com/forum2/viewtopic.php?f=3&t=7930 - I'm about to update it now
Fingers crossed!
pquinton
Post by pquinton » Wed Mar 09, 2016 6:59 am
Just to add my experience with this..
I have had this same error with two separate external USB 3.0 to SATA optical caddies, both with initio chipsets. Even when you run them on a USB 2.0 controller, the issue still exists. I run Makemkv on Linux Mint 17.2 (Debian jessie).
The recent one I tried (this week) was a Startech SLSODDU33B . This has a initio-3619. I've tried different USB 3.0 controllers (chipsets) on different laptops and get the same results, so it does seem to be related to the initio USB 3.0 chips.
As a comparison, I currently run MakeMKV on a seriously cheap USB 2.0 to SATA caddy which detects as: Sunplus Innovation Technology Inc. SPIF30x Serial-ATA bridge. It works fine, just a little on the slow side.
If anyone knows of any working usb 3.0 to SATA caddies, that work on Makemkv linux, I'd be very interested to know about them.
Thanks,
Phil.
alea54
Post by alea54 » Sat Apr 02, 2016 3:26 pm
With makemkv 1.9.9, I have the same problem with an external bluray drive with Initio chipset:
Victsing USB 3.0
It works with makemkv under Windows, but not under Linux.
It is clearly a makemkv problem: discs with old aacs keys work fine with vlc+ the keys from http://www.labdv.com/aacs.
After seeing some messages at the forum, it seems to be an old problem.
So I am wondering if the guys from makemkv work on this issue or if I should send back my drive to the vendor asap.
axkayavoco
Re: makemkv 1.9.10 / initio drive
Post by axkayavoco » Mon Apr 25, 2016 6:26 pm
attached the dmesg output for the external usb drive - makemkv still does not work with this drive.
Fehler 'SCSI-Fehler - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' trat auf während der Übertragung des SCSI-Befehls AD010..0800024C0 zu Laufwerk 'SG:dev_11:3'
[1222662.460019] usb 1-2.1: new high-speed USB device number 16 using ehci-pci
[1222662.570904] usb 1-2.1: New USB device found, idVendor=13fd, idProduct=3940
[1222662.570909] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1222662.570913] usb 1-2.1: Product: INIC-3609
[1222662.570917] usb 1-2.1: Manufacturer: Initio
[1222662.570920] usb 1-2.1: SerialNumber: 30303030303030303030303030303030
[1222662.571203] usb-storage 1-2.1:1.0: USB Mass Storage device detected
[1222662.571305] scsi18 : usb-storage 1-2.1:1.0
[1222663.570576] scsi 18:0:0:0: CD-ROM MATSHITA BD-MLT UJ260AF 1.00 PQ: 0 ANSI: 0
[1222663.579423] sr3: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[1222663.579625] sr 18:0:0:0: Attached scsi CD-ROM sr3
[1222663.579758] sr 18:0:0:0: Attached scsi generic sg4 type 5
