Scsi Errors
jam062307
Scsi Errors
Post by jam062307 »
Since I have updated to windows 10 I have had numerous Scsi errors on multiple blu-rays. Can anyone help fix?
Re: Scsi Errors
Which SCSI errors? Different ones have different causes, but usually they involve the drive simply not being able to read the disk.
Enable debug logging (see FAQ link in my signature) and post the errors here in a reply.
jam062307
Re: Scsi Errors
Post by jam062307 »
Big Bang Theory S7D2 10 episodes ripped, 2 did not
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '613349376'
Quantum of Solace
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '1626273792
Other discs have worked since getting these errors. the discs are clean and scratch free, not sure what I can do to fix it.
compubutt
Re: Scsi Errors
Post by compubutt »
Yes, I am getting the same exact error (but with a different disk), also with Windows 10.
If anyone can figure it out, it would be well appreciated.
Thanks,
msprty858
Re: Scsi Errors
Post by msprty858 »
Started seeing errors like this since upgrading to windows 10 on multiple BluRays
Saving 1 titles into directory C:/Users/Roy/Videos/MKV/CONSTANTINE
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '13270253568'
DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:121263038
DEBUG: Code 0 at =7aE'iYVX@qJ'A7BtXsq:121262302
DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:213130559
DEBUG: Code 6479616 at iaWwv[BA)Fj)ozu9 TD1:29393286
DEBUG: Code 0 at [8elkj;bRJh6^aE%w"Tz':29398967
Failed to save title 0 to file C:/Users/Roy/Videos/MKV/CONSTANTINE/title00.mkv
0 titles saved, 1 failed
or
DEBUG: Code 0 at =7aE'iYVX@qJ'A7BtXsq:121262647
The source file '/BDMV/STREAM/00012.m2ts' is corrupt or invalid at offset 61440, attempting to work around
Hash check failed for file 00012.m2ts at offset 190464, file is corrupt.
File 00012.m2ts was added as title #16
File 00013.m2ts was added as title #17
File 00015.m2ts was added as title #18
Title #00016.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00032.m2ts was added as title #19
File 00033.m2ts was added as title #20
Title #00034.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00035.m2ts was added as title #21
File 00036.m2ts was added as title #22
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00045.m2ts was added as title #23
Re: Scsi Errors
This means the drive said it can't read part of the disk. This usually is a dirty or scratched disk. Sometimes it's a disk that is manufactured incorrectly. Start by cleaning and/or waxing the disk. If it is new, consider returning it for replacement.
If you see uncorrectable error reports, other errors might follow.
These can also be an indication of a read error. Mike has said that sometimes the drive or operating system will NOT report an error when a read fails, but instead will return "something" approximating what was on the disk. If the data is inconsistent, MakeMKV tries to work around it. If it succeeds, the rip continues. If the work arounds all fail, it fails the rip.
I'm a big fan of using Pledge furniture polish to clean/wax ANY disk that reports a read failure. It's helped un-do lots of abuse by family. Out of several thousand DVD and BD disks in the collection, I've only had 5 disks that were defective when new, and one of them was defective in the replacement set, as well.
