makemkv application crashes
Kopitar
#1 Post by Kopitar » Mon Aug 10, 2015 3:56 pm
Hello all,
I downloaded and installed MakeMKV_v1.9.5.exe on Windows 7 SP1 (64bit) machine. After launching application it opens and I see my drive BW-12B1ST. As soon as I try clicking anything in application window (file/view/help or anything inside window) I get a not responding and application has to close. Any suggestions to what might be causing this?
Re: makemkv application crashes
#2 Post by Woodstock » Mon Aug 10, 2015 4:34 pm
Unfortunately, not with the information you've got so far.
If you could, check the Windows Event Manager, and see if there is any information about the crash in it.
Kopitar
#3 Post by Kopitar » Mon Aug 10, 2015 5:29 pm
I ended up installing Setup_MakeMKV_v1.9.4.exe and it worked, took about 19 minutes. I'll have to look into reducing file size. About 20gb for 1968 Planet of the Apes.
Checked event viewer
Log Name: Application
Source: Application Error
Date: 8/10/2015 9:47:01 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer:
Description:
Faulting application name: makemkvcon64.exe, version: 0.0.0.0, time stamp: 0x55b55755
Faulting module name: ntdll.dll, version: 6.1.7601.18869, time stamp: 0x556366f2
Exception code: 0xc0000005
Fault offset: 0x000000000004e108
Faulting process id: 0x1744
Faulting application start time: 0x01d0d383ca89b82b
Faulting application path: C:\Program Files (x86)\MakeMKV\makemkvcon64.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 09cb4ab0-3f77-11e5-8006-3085a992d8fd
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-08-10T15:47:01.000000000Z" />
<EventRecordID>22038</EventRecordID>
<Channel>Application</Channel>
<Computer>DeanLombardi-PC</Computer>
<Security />
</System>
<EventData>
<Data>makemkvcon64.exe</Data>
<Data>0.0.0.0</Data>
<Data>55b55755</Data>
<Data>ntdll.dll</Data>
<Data>6.1.7601.18869</Data>
<Data>556366f2</Data>
<Data>c0000005</Data>
<Data>000000000004e108</Data>
<Data>1744</Data>
<Data>01d0d383ca89b82b</Data>
<Data>C:\Program Files (x86)\MakeMKV\makemkvcon64.exe</Data>
<Data>C:\Windows\SYSTEM32\ntdll.dll</Data>
<Data>09cb4ab0-3f77-11e5-8006-3085a992d8fd</Data>
</EventData>
