Suggestions - Multiple disc in parallel
digsilent
Post by digsilent »
It'll be great if makeMKV can make conversions for a couple of disc (virtual disc/vob/ISO...) at the same time.
Paying no attention, shutting down the computer automatically when the job's done(by checking a "Shutdown automatically" checkbox).
digsilent
Re: Suggestions - Multiple disc in parallel
Post by digsilent »
Or just make the conversion one disc after another, and shut down the computer when achieved.
ndjamena
Post by ndjamena »
You can just write a script that uses MakeMKVCon.exe to do that.
If you're using disc images you should know enough to do it yourself.
Besides, there are MakeMKV frontend GUIs on the forum designed to do just that.
http://www.makemkv.com/forum2/viewtopic.php?f=10&t=9345
http://www.makemkv.com/forum2/viewtopic.php?f=10&t=7960
http://www.makemkv.com/forum2/viewtopic.php?f=10&t=6556
