MKV Chapters
Kingpin
MKV Chapters
Post by Kingpin »
When i convert a dvd to MKV file it plays well on my pc with VLC including forward and backwards Chapters.
But when i stream the mkv file to my Dune Prime i can't use the chapters, what went wrong ?
Re: MKV Chapters
Post by mike admin »
Because MakeMKV streams original decrypted format, VOB for DVD and M2TS for Blu-ray. Neither contains chapter information. The new streaming option will be added to program in a near feature that will selve your problem.
Out of curiosity, do you use UPnP streaming? Other than this chapters issue, does it work reliably with your device?
Kingpin
Re: MKV Chapters
Post by Kingpin »
mike admin wrote:Because MakeMKV streams original decrypted format, VOB for DVD and M2TS for Blu-ray. Neither contains chapter information. The new streaming option will be added to program in a near feature that will selve your problem.
Great!
I only stream with NFS/SMB, i setup a different account with only read rights in my NAS and i disabled uPnP because when enabled uPnP it doesn't show my *,iso files and also chapters don't work (it skipped to the next file in the dir instead of jumping to the next chapter in the movie).
Under NFS/SMB everything works flawless even at 20+Mb/s streaming (higher bitrates i have to test it at the moment i don't own a movie with higher bitrates).
Re: MKV Chapters
Do you steam from MKV, as selecting "stream" from menuu; or you create MKV files and then play them over network? If latter, you should see chapters.
Kingpin
Re: MKV Chapters
Post by Kingpin »
mike admin wrote:Do you steam from MKV, as selecting "stream" from menuu; or you create MKV files and then play them over network? If latter, you should see chapters.
I play mkv files from my NAS to my Dune.
