When i convert a dvd to MKV file it plays well on my pc with VLC including forward and backwards Chapters.
But when i stream the mkv file to my Dune Prime i can't use the chapters, what went wrong ?
						MKV Chapters
 - Contact:
Re: MKV Chapters
Because MakeMKV streams original decrypted format, VOB for DVD and M2TS for Blu-ray. Neither contains chapter information. The new streaming option will be added to program in a near feature that will selve your problem.
Out of curiosity, do you use UPnP streaming? Other than this chapters issue, does it work reliably with your device?
Re: MKV Chapters
Great!mike admin wrote:Because MakeMKV streams original decrypted format, VOB for DVD and M2TS for Blu-ray. Neither contains chapter information. The new streaming option will be added to program in a near feature that will selve your problem.
I only stream with NFS/SMB, i setup a different account with only read rights in my NAS and i disabled uPnP because when enabled uPnP it doesn't show my *,iso files and also chapters don't work (it skipped to the next file in the dir instead of jumping to the next chapter in the movie).Out of curiosity, do you use UPnP streaming? Other than this chapters issue, does it work reliably with your device?
Under NFS/SMB everything works flawless even at 20+Mb/s streaming (higher bitrates i have to test it at the moment i don't own a movie with higher bitrates).
 - Contact:
Re: MKV Chapters
Do you steam from MKV, as selecting "stream" from menuu; or you create MKV files and then play them over network? If latter, you should see chapters.
						Re: MKV Chapters
I play mkv files from my NAS to my Dune.mike admin wrote:Do you steam from MKV, as selecting "stream" from menuu; or you create MKV files and then play them over network? If latter, you should see chapters.
