1.5.2 makemkvcon crashes
eMpTy3000
Post by eMpTy3000 »
I just had a user of Auto Rip n Compress tell me that MakeMKV version 1.5.2 does not work. Makemkvcon.exe and makemkvcon64.exe crash right after it says "Using direct direct disc access mode." I downloaded 1.5.2 and have the same problem. The user reverted back to 1.5.1 and all is well for him. Can you take a look?
Is anybody else having this issue?
setarip_old
Re: 1.5.2 makemkvcon crashes
Post by setarip_old »
What is "Auto Rip n Compress"?
eMpTy3000
Post by eMpTy3000 »
setarip_old wrote:What is "Auto Rip n Compress"?
A Windows 7 Media Center Application. Check it out here: http://thegreenbutton.com/forums/t/81697.aspx
setarip_old
So, does your question have anything to do with using MakeMKV by itself, or is it related only to accessing Make MKV with your GUI?
eMpTy3000
Post by eMpTy3000 »
setarip_old wrote:So, does your question have anything to do with using MakeMKV by itself, or is it related only to accessing Make MKV with your GUI?
It has to do with the command line utilities included with MakeMKV, makemkvcon.exe and makemkvcon64.exe. Neither of these work properly in 1.5.2 (at least in my testing) when calling the command line applications from either my application or doing it from the command line itself. The MakeMKV gui works fine.
Post by mike admin »
Confirmed. Use 1.5.1 or wait for 1.5.3 , sorry.
eMpTy3000
Post by eMpTy3000 »
mike admin wrote:Confirmed. Use 1.5.1 or wait for 1.5.3 , sorry.
Thanks for confirming.
