Madagascar 3
hlorri
Madagascar 3
#1 Post by hlorri » Wed Aug 05, 2015 8:50 am
Most of the bonus material rips fine, but the main movie (track 2) fails:
MakeMKV v1.9.5 linux(x64-release) started
Title #00096.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.mpls was added as title #0
Title #00001.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01000.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00127.mpls was added as title #1
File 00400.mpls was added as title #2
File 00150.mpls was added as title #3
Title #00035.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00179.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00334.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00357.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00397.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00399.m2ts was added as title #4
Title #00401.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00795.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00950.m2ts was added as title #5
Title #00951.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00955.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00961.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00962.m2ts has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01118.m2ts was added as title #6
File 01120.m2ts was added as title #7
Title #01121.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01122.m2ts was added as title #8
File 01123.m2ts was added as title #9
Title #00025.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01125.m2ts was added as title #10
Title #01126.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01127.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01128.m2ts was added as title #11
Title #01129.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01130.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01131.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01132.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01133.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00221.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00222.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00223.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00224.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00287.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00288.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00386.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01119.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory /home/shared/Videos/Madagascar_3_Europe's_Most_Wanted
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/01118.m2ts' at offset '1115353088'
Failed to save title 0 to file /home/shared/Videos/Madagascar_3_Europe's_Most_Wanted/Madagascar_3_Europe's_Most_Wanted_t00.mkv
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/01118.m2ts' at offset '1114173440'
Failed to save title 6 to file /home/shared/Videos/Madagascar_3_Europe's_Most_Wanted/Madagascar_3_Europe's_Most_Wanted_t06.mkv
0 titles saved, 2 failed
Re: Madagascar 3
#2 Post by Woodstock » Wed Aug 05, 2015 2:07 pm
Your drive is getting confused on where to go next when reading some of the tracks. There isn't much MakeMKV can do about that.
If this is the only disk it's happening on, it is most likely the disk itself, either dirty, damaged, or manufactured poorly. Sometimes, there are tracks that have deliberate navigation problems, but I don't remember this title one being reported as such.
If it happens on multiple disks, there might be something in the drive preventing it from reaching part of the disk. That is rare, but it does happen.
