Insurgent retail
tonyg241
Insurgent retail
Post by tonyg241 » Tue Aug 04, 2015 8:59 pm
Wondering if anyone has the correct segment map for retail copy of Insurgent.
03-firefly-k64
Re: Insurgent retail
Post by 03-firefly-k64 » Wed Aug 05, 2015 12:46 am
510, 509, 506, 502, 504, 508, 505, 511, 501, 507, 503
Amazon retail title 407
I've gotten info from this forum for years. Happy I can finally contribute!
tonyg241
Post by tonyg241 » Wed Aug 05, 2015 12:48 am
Thanks for the help! :D
JosephEC
Post by JosephEC » Wed Aug 05, 2015 2:05 am
Definitely, thanks for the help! :)
augerpro
Post by augerpro » Wed Aug 05, 2015 11:37 am
Is there new protection here? PM is showing the last mpls in local cache:
Looks like 286 to me?
Zonian
Post by Zonian » Wed Aug 05, 2015 1:10 pm
PowerDvd and Procmon gave me the same as the guy posted above for the redbox version. I thought it was 00437 but it is definitely wrong as the ending is out of order. It seems 00721 correct. However, I am now confused as to how to figure this out on my own!?
03-firefly-k64
Post by 03-firefly-k64 » Wed Aug 05, 2015 5:27 pm
I can look in my log file when I get home from work, but I'm pretty sure 437, 003, and 286 are transition segments. They are very brief in time and 503, for me at least, takes me to the end of the credits which is all I need.
With obsfucation over the last few years, there have been many different results regarding which title works for who. Once, it was retailers all had different titles, but now I'm finding that even two disks bought from the same source may differ in the correct title. The only guarantee is matching the right segment map. I haven't yet found segment maps that differ across disks even if the resulting title does.
If you find it yourself, pay attention to what the movie is doing and when. Don't just let it run and come back to the ProcMon some time later. I will typically fast forward ~8x thru the movie in one corner of my screen and keep ProcMon running on the other side. This allows me to catch when questionable segments are linked to unrequired material such as warnings, menus, and whatnot.
I'm not sure if this helps. But I tried.
DJRumpy
Post by DJRumpy » Wed Aug 05, 2015 8:33 pm
I have an amazon disk (1 disk) UPC 0 31398 22406 8
If the three I'm seeing are correct, this one looks good on mpls 407.
Haven't watched it yet for errors.
407.mpls
510,509,506,502,504,508,505,511,501,507,503
augerpro
Post by augerpro » Thu Aug 06, 2015 11:19 am
DJRumpy wrote:I have an amazon disk (1 disk) UPC 0 31398 22406 8
If the three I'm seeing are correct, this one looks good on mols 407.
407.mpls
Could you post a screen shot?
DaveK8
Post by DaveK8 » Thu Aug 06, 2015 6:45 pm
Has anyone figured out the correct segment map for the 3 disc US Amazon retail version (3D Blu-ray, Blu-ray, DVD) yet? At this point, I'm only interested in the standard 2D Blu-ray (disc 2) of the set. The UPC code is 0-31398-22544-7-80. Thanks.
DJRumpy
Post by DJRumpy » Fri Aug 07, 2015 12:33 am
I've verified that the single disk mpls I ripped above is the correct one. Plays without issue with no gaps or glitches.
critical
Post by critical » Fri Aug 07, 2015 5:02 am
I have the single disc retail version from Costco.
Would like to confirm that the correct segment for me was also 510,509,506,502,504,508,505,511,501,507,503
The only difference is that the segment was located in title 83.
I compared the rip and the disc, taking note of chapter length and scenes, everything matched up perfectly.
augerpro
Post by augerpro » Fri Aug 07, 2015 9:53 pm
augerpro wrote:Is there new protection here? PM is showing the last mpls in local cache:
So I ripped 286 and compared with the movie, about half way through it had the wrong scene. Looking at 437 from above the order does not match early in the movie so that isn't it. 3 is very short and in mpeg2 so I don't know what that is all about. Looks like they figured out a way to trick the PM method. And with hundreds to choose from I'll never find the right one. Now what?
augerpro
Post by augerpro » Fri Aug 07, 2015 10:37 pm
Zonian wrote: It seems 00721 correct. However, I am now confused as to how to figure this out on my own!?
721 is correct for me too. How did you know this was correct?
DJRumpy
Post by DJRumpy » Fri Aug 07, 2015 10:55 pm
Some people have BD players that list the files that are opened for each chapter. They also narrow down by play time (many times the lengths all differ). Some also use AnyDVD to get a list of 'valid' MPLS. Sometimes it's a combination of the above. It just takes time and a little help from the community too. If you also have a difficult one, Mike the Admin can also take a look sometimes. It may require that you upload some debugging files though.
