Problem with subtitles in Avatar
Commander
Post by Commander »
i have some problems with the avatar rip. There are used 2 different subtitles (german) and i marked the second one cause that is the one to show all talking when the aliens use there own language. The problem is, when you mark that subtitle, it is shown for the first time and all is fine but the last words that are shown do no more disappear. They are shown until there is a new talk. You have to de-select the subtitle and select it again. Any ideas?
Re: Problem with subtitles in Avatar
Post by mike admin »
Looks like a player problem. What player do you use?
Commander
Post by Commander »
I use the Dune BD Prime 3.0 player.
jmerrilljr
Post by jmerrilljr »
This seems to be a problem with ffmpeg. Subtitles are "sticky" in the XMBC betas and also the hot fixed Plex 9.
Commander
Post by Commander »
jmerrilljr wrote:This seems to be a problem with ffmpeg. Subtitles are "sticky" in the XMBC betas and also the hot fixed Plex 9.
And what can i do now?
DaveOzric
Post by DaveOzric »
I am having this problem with all players I use. VLC, Plex Server on Rock. Is there any solution besides re-encoding to something with hardcoded subs?
The problem you attached to is from 2010.... A lot has changed in 5 years! Support for PGS subtitles in MKV files has come to most player software an a lot of hardware players.
The problem is that many will ignore flags like "default" and "forced"; You just have "on" and "off" for whole tracks, and might not have the correct one displayed. Knowing how your particular player handles them will lead you to which tools are needed to "fix" it.
DaveOzric
Post by DaveOzric »
I realized this too and am going to try it from scratch and see. Thanks
