Would it be possible to sort the main list (with title selection) based on the Source File Names?
I have been ripping some TV shows on Blu-Ray, and when the listing comes up, the source file names are often out of order, for example, when I select the title, on the right, I get: 'Source file name: 00005.mpls', but its not the fifth one down. The episode order on the disc usually corresponds to the source file name, but MakeMKV will sometimes get the source file names out of order. (i.e. source file 0005.mpls will be the second in the list in MakeMKV and will be saved as title01.mkv.
Thank you.
FYI: Im using 1.5.2
Suggestion: Main List Ordering
- Contact:
Re: Suggestion: Main List Ordering
They are sorted as they are physically on disc. Request noted, can't promise any specific dates.
