Won't install; says MKV is already running...
DefiniteChoice
Post by DefiniteChoice »
Hi guys! Hopefully I came to the right place.
I got the message my version had expired and to re-download, which I did, but when I try to install it the installer says MKV is running and to close it before it can continue. I closed everything, don't see anything MKV in Task Manager, and even re-booted my computer but I still get the message.
What gives?
Re: Won't install; says MKV is already running...
Have to wait for Mike on this one - if, after a reboot, it says MakeMKV is still running, there is probably a file somewhere that it depends upon which is being locked by another task.
DefiniteChoice
Hmmmm weird, well I do look forward to any tips, thanks!
Chetwood
Post by Chetwood »
Just to be sure, there was also no makemkvcon.exe listed in task manager?
DefiniteChoice
Correct
Kikidy
Post by Kikidy »
Did anyone ever figure this out?
As I am having this problem with 1.10.7, not 1.10.6 though.
yorgo
Post by yorgo »
If you're on a Windows machine, do as Chetwood suggested; open Task Manager and kill makemkvcon.exe and any other MakeMKV functions, has always worked for me. Also, try restarting your computer, see if that helps.
JBlue
Post by JBlue »
I know this is a really old post, however I had a similar problem and eventually got the installation to work. Not sure if others do the same thing as me, but I typically rename the files I download to something a little simpler and straight-forward (eg: "Setup_MakeMKV_v1.12.3" to "MakeMKV")... For some reason that was the cause for MakeMKV to not install.
I re-downloaded the file without renaming it and it worked perfectly.
Not sure if others are renaming the files they download, but it can cause installation issues in some programs.
