Megamind
cpercival
Megamind
Post by cpercival » Fri Jul 31, 2015 2:05 pm
I get a failure on this one every time. It will get maybe halfway through before failing. I tried cleaning the disc, but it looks flawless. Tried rebooting. Tried a friend's copy - mine is the special edition and I wondered if that had something to do with it. This is the first time I've had trouble after ripping about 300 or so movies over the years.
Re: Megamind
Post by Woodstock » Fri Jul 31, 2015 2:45 pm
It would be helpful to see the debug log on this, to see what kind of errors you're experiencing.
cpercival
Re: Megamind
Post by cpercival » Fri Jul 31, 2015 3:17 pm
Woodstock wrote:It would be helpful to see the debug log on this, to see what kind of errors you're experiencing.
I'll grab it when I get home tonight. How do I post it? Do I just paste it here, add it as an attachment, or do I post a link to a Dropbox folder or something similar?
Re: Megamind
Post by Woodstock » Fri Jul 31, 2015 7:21 pm
Easiest to read is to click the "Code" button above the editor box, and paste the log in between the two tags that will appear.
cpercival
Re: Megamind
Post by cpercival » Sat Aug 01, 2015 2:56 pm
Alright, here it is:
Debug log started at Sat Aug 01 12:03:59 2015 , written by MakeMKV v1.9.5 win(x64-release)
001005:0000 MakeMKV v1.9.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Chad/MakeMKV_log.txt
001003:0020 DEBUG: Code 100864261 at 8~1}?:Qb]C~:!]x^:121269731
DEBUG: Code 2147483648 at ^%89q5[n5PypdO,l:121265315
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=ngNjBvhgxjK8Zag7PFyZIrhWxiV22xwZ19nCf6ivSWW/TWeznDqActtunE5nnusGVDdtLniFMXGuMW6MInI97WTL+o6oRZ/rt73HAryoqQ4ofNxj0VP2Vyj80Xp6AgNzSRzNdkOoByzkHG7sGBBly9E8tIxY/cnPkA==
DCE=ANO5TmvAxfUp8gB0WSHlvQakgVvX6k+SXzNp9FOfSnTQI0XXTHqUM9lvTZYVGEd8AKiKqVf7TTzDJkUgdnA3HGCx4IqWramgXIGYLcajJLXI1GSSX+5L3cTF+8HlAgMJpdMUg9ODdbr7LT5p5slhXZ2tOm1UP7HRzw==
DISCID=F516FF92990D5BA279ACF2786748C397EED82641
003025:0000 Title #00096.mpls has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00010.mpls has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00011.mpls has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00012.mpls has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00013.mpls has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003307:0000 File 00000.mpls was added as title #0
003025:0000 Title #00001.mpls has length of 101 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #01000.mpls has length of 90 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #01001.mpls has length of 90 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00005.mpls has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00200.mpls has length of 316 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003309:0000 Title 00601.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00602.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00603.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00604.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00605.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00606.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00607.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00608.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00609.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00621.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00622.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00623.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00624.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00625.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00626.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00627.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00628.mpls is equal to title 00000.mpls and was skipped
003309:0000 Title 00629.mpls is equal to title 00000.mpls and was skipped
003025:0000 Title #00004.mpls has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00179.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00180.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00297.m2ts has length of 566 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00298.m2ts has length of 96 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00334.m2ts has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00357.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00369.m2ts has length of 62 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00370.m2ts has length of 127 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00371.m2ts has length of 62 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003307:0000 File 00372.m2ts was added as title #1
003025:0000 Title #00394.m2ts has length of 76 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00395.m2ts has length of 100 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00396.m2ts has length of 62 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00397.m2ts has length of 109 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00398.m2ts has length of 57 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00399.m2ts has length of 156 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00400.m2ts has length of 62 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00401.m2ts has length of 63 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00402.m2ts has length of 83 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00403.m2ts has length of 63 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00404.m2ts has length of 54 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00219.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00220.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00221.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00222.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00223.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00224.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00287.m2ts has length of 45 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00288.m2ts has length of 45 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00386.m2ts has length of 50 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00387.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00388.m2ts has length of 3 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00389.m2ts has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00390.m2ts has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00391.m2ts has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00392.m2ts has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00393.m2ts has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
003025:0000 Title #00458.m2ts has length of 1 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory E:/Movies/Megamind (2010)
001003:0020 DEBUG: Code 3221225628 at 65f*?&E;3`.V2!/4LOphQw({$:121263521
001003:0020 DEBUG: Code 3221225628 at S@|C4YnmLkr|*7E[:29393953
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00372.m2ts' at offset '401141760'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00372.m2ts' at offset '476577792'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00372.m2ts' at offset '477032448'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00372.m2ts' at offset '478605312'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00372.m2ts' at offset '5990449152'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00372.m2ts' at offset '5991432192'
001003:0020 DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:121263038
001003:0020 DEBUG: Code 0 at =7aE'iYVX@qJ'A7BtXsq:121262302
001003:0020 DEBUG: Code 0 at iaWwv[BA)Fj)ozu9 TD1:213130559
001003:0020 DEBUG: Code 2925504 at iaWwv[BA)Fj)ozu9 TD1:29393286
001003:0020 DEBUG: Code 0 at [8elkj;bRJh6^aE%w"Tz':29398967
005003:0000 Failed to save title 0 to file E:/Movies/Megamind (2010)/Megamind_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Aug 01 14:41:12 2015
Re: Megamind
Post by Woodstock » Sun Aug 02, 2015 2:07 am
Mike will have to look at the debug codes, but, these type of errors often lead to the debug codes:
According to Mike, some drive/operating system combinations do not return error codes for all errors - sometimes, SOMETHING will be returned, but not necessarily correct data. When this happens, MakeMKV tries to make sense of it... After all, there was no "error", so it should be real data, right?
The debug codes are where MakeMKV is trying different work-arounds to figure out the data it received. Sometimes it works... Sometimes it doesn't. But each of them gives information to Mike to determine what is going on. He may ask you to do a "testdump" and send him the file, but I'd wait to hear from him before doing so.
As for "special editions", they're usually different from "standard editions" in the extras, rather than the actual movie. There are exceptions; some have different versions of the feature included, such as Blade Runner.
cpercival
Re: Megamind
Post by cpercival » Sun Aug 02, 2015 10:45 pm
Should I send this log to makemkv support then?
Re: Megamind
Post by Woodstock » Mon Aug 03, 2015 12:26 am
If you're going to send the log, include the information files from the disk, too. The list of what to send is included in the FAQ link in my signature.
More information is usually better than less, so I think you should send it.
cpercival
Re: Megamind
Post by cpercival » Mon Aug 03, 2015 11:52 am
The directions read "please copy all *.CLPI files from BDMV\CLIPINF directory and all *.MPLS files from BDMV\PLAYLIST directory."
What are those and where do I find them?
Sorry for the noob questions and thanks for the help
Re: Megamind
Post by Woodstock » Mon Aug 03, 2015 12:29 pm
On the BD itself. If you use Windows Explorer, select your BD drive, and you will find directories on it. Let's say your BD drive is mapped as "G"; The files Mike needs are in G:\BDMV\CLIPINF and G:\BDMV\PLAYLIST, with the file extensions listed.
comncens
Re: Megamind
Post by comncens » Mon Aug 31, 2015 3:26 pm
Was this issue resolved? I am presently having the same problem with Megamind.
Thank you.
