Are read errors always down to the disk or drive?
jCurve
Post by jCurve » Fri Jul 31, 2015 1:57 am
I'm looking at ripping a number of Blu Rays to avoid kids damaging the disks and all sources point to this being the best software to use. what i am finding so far however is that all 4 of the Blu Rays i have tested on are giving me: Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED or similar, what appear to be read related errors. All the searching I have done here seems to point to this either being a dirty or poorly manufactured disk or a failing drive. The highest encryption I have hit is AACS v31 on 'Frozen' and FYI I am running OS X 10.10.4 MakeMKV v1.9.5.
The thing is these discs have no scratches and play back just fine on the same drive using Mac Blu Ray Player.
I know from past experience that DVD's have thrown up read errors as programs try to read past scrambled data and can't due to encryption. Is there a difference in the reading for this program than there is reading to play the disc that makes it more sensitive to manufacture faults.
Are we 100% sure this is not an encryption issue?
Just in passing. every DVD has gone through without fail. it is just the Blu Rays
Thanks for your time
J
Re: Are read errors always down to the disk or drive?
Post by Woodstock » Fri Jul 31, 2015 2:35 pm
If the log shows SCSI errors, that's what the operating system reported to MakeMKV when it requested the read. Based upon the "retries exhausted", MakeMKV asked its normal 5 times before logging the error.
If you could, please post the debug log with the specific error codes and any debug messages, so that Mike can have better information to work with.
jCurve
Post by jCurve » Sat Aug 01, 2015 1:40 am
Thanks.
The latest attempt had this as the Log:
MakeMKV v1.9.5 darwin(x86-release) started
Optical drive "BD-RE SONY BD RW BDX-S500U 1.D1d" opened in OS access mode.
Optical drive "BD-ROM WD Virtual CD 1110 1030" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Evaluation version, 29 day(s) out of 30 remaining
Title #00000.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00810.mpls was added as title #0
File 00800.mpls was added as title #1
File 00801.mpls was added as title #2
File 00802.mpls was added as title #3
File 00300.mpls was added as title #4
File 00200.mpls was added as title #5
File 00205.mpls was added as title #6
File 00206.mpls was added as title #7
Title 00809.mpls is equal to title 00200.mpls and was skipped
Title #00011.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00513.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00514.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00516.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00517.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00519.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00520.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00872.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00873.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00874.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00876.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00879.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00880.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00881.m2ts was added as title #8
Title #00882.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00883.m2ts was added as title #9
Title #00884.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00885.m2ts has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00886.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00887.m2ts was added as title #10
File 00888.m2ts was added as title #11
Title #00800.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00889.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00890.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00891.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00892.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00893.m2ts was added as title #12
Title #00894.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00895.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00896.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00897.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00898.m2ts was added as title #13
File 00899.m2ts was added as title #14
File 00902.m2ts was added as title #15
Title #00904.m2ts has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00905.m2ts was added as title #16
Title #00906.m2ts has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00907.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00908.m2ts was added as title #17
File 00909.m2ts was added as title #18
File 00910.m2ts was added as title #19
File 00911.m2ts was added as title #20
Title #00912.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00914.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00915.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00916.m2ts was added as title #21
Title #00917.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00918.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00919.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00920.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00921.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00922.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00923.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00924.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00926.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00927.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00928.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00929.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00930.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00931.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00932.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00933.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00810.mpls is equal to title 00800.mpls and was skipped
Saving 1 titles into directory /Users/JDS/Movies/Frozen
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00883.m2ts' at offset '1380974592'
Failed to save title 0 to file /Users/JDS/Movies/Frozen/Frozen_t00.mkv
0 titles saved, 1 failed
As 00883 seems to be the problem child i've tried to do a direct copy of that file to the desktop and hit:
The Finder can’t complete the operation because some data in “00883.m2ts” can’t be read or written.
(Error code -36)
I also tried disk imaging in toast which failed and I am currently trying disk utility but i don't hold out much hope. The only success I had was with 'Brorsoft' which did it but it took about 5 hours. Even though MakeMKV is having read issues with the disks I have tested I can see it will be far faster when it does so i know what i'd rather pay for.
J
Post by Woodstock » Sat Aug 01, 2015 2:11 am
I noticed this:
Mike has generally discouraged people from installing the DASPI extension on OS X unless the program reports it would help... In your case, it looks like it might.
To date, I have not seen MakeMKV report a copy-protection-related problem as a SCSI failure to read error. That doesn't mean it can't happen, but I have never seen it. When the operating system says there is an error, it's just reporting what the drive said. You might see key exchange errors on drives that have been hit by AACS, but many of those turn out to be disk read issues.
Lots of words to say, "This is why I have a can of Pledge and a soft cotton cloth on hand next to the ripping computer". :)
