makeMKV v1.5.2 Slysoft VirtualCloneDrive
markb
Post by markb » Mon Mar 22, 2010 10:16 am
Thanks for fixing LPCM with this release!
I mount .ISO files made by AnyDVD using Slysoft Virtual Clone Drive software and makeMKV warns of AnyDVD running.
AnyDVD is not running but the mount software is.
Not a problem but an annoyance.
setarip_old
Re: makeMKV v1.5.2 Slysoft VirtualCloneDrive
Post by setarip_old » Mon Mar 22, 2010 5:23 pm
Hi!
It's not because of your using Virtual Clone Drive (I use it regularly), the message is appearing because your .ISO image file was made using AnyDVD (and apparently carries some identifying information)...
dirio49
Post by dirio49 » Mon Mar 22, 2010 6:51 pm
I think it is annoying too.
There should be an option to turn it off.
Dvdfab and imgburn have the option to turn it off.
Because it gets annoying to get it every time, just a message on the log will be fine with me.
setarip_old
Post by setarip_old » Mon Mar 22, 2010 8:18 pm
I believe this notification will no longer make appearances if you use IMGBurn to create your .ISO image files...
dirio49
Post by dirio49 » Mon Mar 22, 2010 10:33 pm
setarip_old wrote:I believe this notification will no longer make appearances if you use IMGBurn to create your .ISO image files...
That is true.
But what it does is still very annoying
Danger
Post by Danger » Mon Mar 22, 2010 11:04 pm
WOW... If you use IMGBurn to make ISOs, instead of AnyDVD then you will no longer get the "AnyDVD is running..." message :shock:
dirio49
Post by dirio49 » Mon Mar 22, 2010 11:17 pm
Well, I only included (build the image)
The certificate folder and bdmv folder.
That is why I think.
But if you use imgburn to do a image directly I dough that would happen
Post by mike admin » Tue Mar 23, 2010 5:32 am
Noted, probably setting will be added to disable a warning.
