I've got some DVD here with health and safety instructions, I would like to rip into a file.
Title #1 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/1 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/2 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/3 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/4 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/5 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/6 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/7 has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/8 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/9 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/10 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/11 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/12 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/13 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/14 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/15 has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/16 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/17 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/18 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/19 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/20 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/21 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/22 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/23 has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/24 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/25 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/26 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/27 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/28 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/29 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/30 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/31 has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/32 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/33 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/34 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/35 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/36 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/37 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/38 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/39 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/40 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/41 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/42 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/43 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/44 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/45 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/46 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/47 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Manual String parse error : string is empty
//edit: found it on the first page in the options at the bottom. Thanks!
works like a charm
http://i.imgur.com/Zi1EAyG.png
