removed
eva_a
removed
Post by eva_a »
removed
eva_a
removed
Post by eva_a »
removed
Re: Ex Machina
Your drive is unable to read parts of the disk. Usual issue is dirt, finger prints, or scratches, although it is not unheard of to have a disk that was not manufactured correctly.
dschreiber69
Re: Ex Machina
Post by dschreiber69 »
I am getting the same errors
Re: Ex Machina
Same errors in the same locations?
syntax53
Re: Ex Machina
Post by syntax53 »
same problem with this disc
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00276.m2ts' at offset '23604295680'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00276.m2ts' at offset '23605936128'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '23605936128'
Re: Ex Machina
Again, signs of a scratched or dirty disk, unless you're seeing the same errors on other DVDs and BDs ripped in the drive.
syntax53
Re: Ex Machina
Post by syntax53 »
Update: My disk was a netflix disk so I sent it back as damaged and they sent a new one and it worked fine. Maybe just crappy materials/process on this movie.
MZAdotcom
Re: Ex Machina
Post by MZAdotcom »
I received 2 bad discs back to back from Netflix. Just gave up; might try to get another one down the road. Seems when this happens, it's a good chance a bad batch is to blame.
@HTPC: Intel NUC HTPC [BOXDN2820FYKH0] | Plextor 128GB SIII SSD | G.SKILL 8GB DDR3 1333 RAM | Win 10 Pro | SAMSUNG 55" LED HDTV | Harman/Kardon 5.1 AV Receiver [AVR 1565] | Dolby TrueHD | DTS-MA HD | Polk Audio 5.1 Home Theater System w/10" SW
Re: Ex Machina
When I had Netflix DVD service, I would occasionally send a disk back as "bad", and get the exact same disk again as a replacement. Sometimes, they'd polish it and send it back.
