1.9.4 - Save Error
uv_goth
1.9.4 - Save Error
Post by uv_goth »
I update ffmeg as instructed. Running Kubuntu 12.04.5. Trying to rip a UK DVD.
Can anyone shed light on why it's failing?
Saving 1 titles into directory /files/Documents/Videos
AV synchronization issues were found in file '/files/Documents/Videos/title09.mkv' (title #10)
AV sync issue in stream 0 at 0:05:41.560 : video frame timecode differs by +27.6s
AV sync issue in stream 1 at 0:05:41.376 with duration of 3723.07ms : audio gap - 116.345 missing frame(s)
AV sync issue in stream 0 at 1:21:07.440 : video frame timecode differs by +27.593s
AV sync issue in stream 0 at 1:21:12.440 : video frame timecode differs by +27.6s
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_12_1.VOB' at offset '418029568'
DEBUG: Code 0 at .=._&[\4=7xV4E]b:6YT:121263038
DEBUG: Code 0 at p;D:d/tEguu=<cD_fIl:121261750
DEBUG: Code 0 at .=._&[\4=7xV4E]b:6YT:213130559
DEBUG: Code 2301268 at .=._&[\4=7xV4E]b:6YT:29393286
DEBUG: Code 0 at JX2FxVu)tcE}.y}$Z}>Pm:29398967
DEBUG: Code 0 at 6PDNg3qr}ii:Cy&t{Zx:29396414
DEBUG: Code 0 at IV?:|)c;kSa#/|NT,:213131893
DEBUG: Code 0 at IV?:|)c;kSa#/|NT,:121263406
DEBUG: Code 0 at IV?:|)c;kSa#/|NT,:29393907
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 9 to file /files/Documents/Videos/title09.mkv
0 titles saved, 1 failed
Re: 1.9.4 - Save Error
Your drive can't read parts of the disk, due to either dirt, scratches, or an otherwise bad disk. There were symptoms before the read errors - time sync errors of 27 SECONDS due to missing frames.
Start with cleaning the disk, perhaps waxing it. Use a soft cotton or microfiber cloth, to avoid adding scratches. Use water-based cleaners, to avoid damaging the surface chemically. Sometimes enabling more retries can get past errors like this.
