Back Up Failed 2001 A Space Odessy
ogmiii
#1 Post by ogmiii » Wed Jul 22, 2015 3:59 pm
Using MakeMKV 1.9.4 on a MacPro OSX 10.10.4 following results, please advise:
Wade
MakeMKV v1.9.4 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/Wade1/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH41N PQ06d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BE12LU38 1.00d" opened in OS access mode.
Backing up disc into folder "/Users/Wade1/Movies/backup/2001 A Space Odyssey"
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE HL-DT-ST BD-RE BE12LU38 1.00' at offset '24999165952'
DEBUG: Code 101016576 at esZ8@_zv+u~)<',]#l:121262670
DEBUG: Code 100806658 at esZ8@_zv+u~)<',]#l:121262670
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading 'BD-RE HL-DT-ST BD-RE BE12LU38 1.00' at offset '24999165952'
DEBUG: Code 0 at WRn{wW>gh)%6P.p%:29400830
DEBUG: Code 0 at a_Q5wVyL[1G4+rte5`A:29399335
DEBUG: Code 0 at a_Q5wVyL[1G4+rte5`A:121265039
DEBUG: Code 0 at ut+p,,:UL8EU_k)k]*NX:121265108
Backup failed
Re: Back Up Failed 2001 A Space Odessy
#2 Post by Woodstock » Wed Jul 22, 2015 4:06 pm
While Mike will have to translate what the debug codes mean as far as processing errors, the "go to" answer on this is to clean the disk.... Fingerprints in the wrong place (or scratches) can cause this type of problem, depending upon the drive.
ogmiii
#3 Post by ogmiii » Thu Jul 23, 2015 2:43 am
Carefully cleaned, nary a fingerprint, same failure.
W
