no watchable rips from BluRay
jnorvell
Post by jnorvell » Mon Jul 20, 2015 6:44 pm
I installed MakeMKV on Gentoo linux. It rips from dvds just fine. BDs open, MakeMKV says they're being decrypted and rips them without error messages. Every single one I have tried (more than a dozen, most of them at least four or five years old) have the blotchy, pixelation breaks I think are connected with BD+. What am I missing here?
John
Re: no watchable rips from BluRay
Post by Woodstock » Tue Jul 21, 2015 1:55 am
What CODEC was used for the video on the BDs? What are you using to play them?
Current versions of MakeMKV should already have applied the BD+ fix-up information when decripting and writing the MKV files. If it didn't, you should see an entry in the log about "No FUTs found". I don't THINK that part of MakeMKV is dependent upon external libraries, but I didn't write it, so I can't say for sure.
Mikemk
Post by Mikemk » Tue Jul 21, 2015 1:58 am
I've noticed a wrong color/pixelesque effect can happen on older/slower computers when playing BD rips. What are your specs?
jnorvell
Post by jnorvell » Tue Jul 21, 2015 6:13 pm
Thanks for the replies.
I did not see any error message about FUTs. How would I see which codec is used on the disk? I was playing the MKV files with VLC. My hardware specs are Intel Core2 2.66GHz, 6GB RAM, GeFOrce GT 630 display adapter. I run Gentoo Linux, kernel 3.12-13.
I'm trying resizing and transcoding to x264 right now to see if that makes it playable.
jnorvell
Post by jnorvell » Tue Jul 21, 2015 7:40 pm
Thanks again. I guess it was just memory or CPU capacity. I resized the file by about half and it plays fine. It fit the BD+ issue description, so I just assumed that is what was happening.
Post by Woodstock » Tue Jul 21, 2015 7:42 pm
Usually when you're ripping the disk, MakeMKV can show you the video CODEC by clicking on the little triangle next to the title in the left menu. This expands the information, and lets you look at each track that makes up a title.
VLC should be able to handle any CODECs, but be aware that it does NOT do well if there is any delay in your system. If I'm doing a rip to the media server AND a copy from it, trying to play a BD track (and sometimes a DVD track) can result in grey, pixelated screens periodically, where VLC got to the end of the data buffer before the file system could refill it. The area where the volume slider is will change color when this happens, as it tries to refill the buffer.
ndjamena
Post by ndjamena » Wed Jul 22, 2015 9:16 am
Is using all upper case for the word "codec" the standard somewhere?
I keep thinking you're deliberately trying to emphasise the word and it's throwing me off...
Post by Woodstock » Wed Jul 22, 2015 2:16 pm
CODEC isn't a "normal" word... it's an concatenation of (depending upon who you ask) "coder/decoder" or "compressor/decompressor". While a LOT of people think of it as a word, I prefer to point out that it isn't.
Treating it as if it is a "stand alone word" belies the nature of its origins. It falls into the category of "assumed knowledge" that we all get caught up in, assuming that anyone reading what we write knows all the buzz words. But not everyone does. Using uppercase for it, in my opinion, signals that it is OK to not know what this is, and maybe it should be looked up.
So, you're assumption that I'm "deliberately trying to emphasise the word" is correct, but the part about doing it to throw you off isn't. :)
ndjamena
Post by ndjamena » Thu Jul 23, 2015 1:18 am
OK, I'd tend to think it's giving me a headache, but I'd probably have one anyway.
I'll just make sure to harden my mind against any possible uses of the words LASER, TASER, SCUBA and... oh god, thankfully this isn't a chemistry forum. At least there's that. :P
Mikemk
Post by Mikemk » Thu Jul 23, 2015 5:07 am
ndjamena wrote:oh god, thankfully this isn't a chemistry forum. At least there's that. :P
I C U
ndjamena
Post by ndjamena » Thu Jul 23, 2015 8:05 am
Woodstock wrote:but the part about doing it to throw you off isn't. :)
I said nothing like that.
(In case you hadn't noticed, he's doing it deliberately.)
