Compile options for up to date ffmpeg not working.
miklnk
Post by miklnk » Sun Jul 12, 2015 2:02 am
I tried compiling makemkv-oss-1.9.4 with the latest version of ffmpeg with the suggested configure flags of:
./configure --prefix=/tmp/ffmpeg --enable-static --disable-shared --enable-pic --disable-yasm
but the configure script returns:
configure: WARNING: unrecognized options: --enable-static, --disable-shared, --enable-pic, --disable-yasm
Anyone know what is going on here?
rickyjm
Re: Compile options for up to date ffmpeg not working.
Post by rickyjm » Tue Jul 14, 2015 3:04 pm
Hi, either something needs to be updated or make sure that you're in the correct directory when executing that command?
Always back it up. Image
Mikemk
Post by Mikemk » Tue Jul 21, 2015 2:30 am
It worked for me about 62 minutes ago using ffmpeg 2.7.2
