I just had a user of Auto Rip n Compress tell me that MakeMKV version 1.5.2 does not work. Makemkvcon.exe and makemkvcon64.exe crash right after it says "Using direct direct disc access mode." I downloaded 1.5.2 and have the same problem. The user reverted back to 1.5.1 and all is well for him. Can you take a look?
Is anybody else having this issue?
1.5.2 makemkvcon crashes
Re: 1.5.2 makemkvcon crashes
What is "Auto Rip n Compress"?
A Windows 7 Media Center Application. Check it out here: http://thegreenbutton.com/forums/t/81697.aspxsetarip_old wrote:What is "Auto Rip n Compress"?
So, does your question have anything to do with using MakeMKV by itself, or is it related only to accessing Make MKV with your GUI?
It has to do with the command line utilities included with MakeMKV, makemkvcon.exe and makemkvcon64.exe. Neither of these work properly in 1.5.2 (at least in my testing) when calling the command line applications from either my application or doing it from the command line itself. The MakeMKV gui works fine.setarip_old wrote:So, does your question have anything to do with using MakeMKV by itself, or is it related only to accessing Make MKV with your GUI?
- Contact:
Confirmed. Use 1.5.1 or wait for 1.5.3 , sorry.
Thanks for confirming.mike admin wrote:Confirmed. Use 1.5.1 or wait for 1.5.3 , sorry.
