Fun with Manual Mode
dred1367
#1 Post by dred1367 » Fri Jul 17, 2015 8:58 am
I've been trying to rip Hey Arnold! and Rocko's Modern Life Complete Series DVDs.
The problem I'm running into is that each episode on disc contains 2 15 minute episodes, and in order for THETVDB to scrape properly, I need to split those episodes.
Example: S01E01 on disk contains S01E01 & S01E02
The string would work out to the following (I worked it out by matching titles and chapters in VLC):
3:1-2;3:3-4;6:1-2;6:3-4;9:1-2;9:3-4;18:1-2;18:3-4;15:1-2;15:3-4;21:1-2;21:3-4;11:1-2;11:3-4
Which, for some reason doesn't work. It gives me the following error:
Optical drive "BD-ROM WD Virtual CD 1112 1004" opened in DASPI v1.5 mode.
Open DVD manually : "3:1-2;3:3-4;6:1-2"
Manual String parse error : chapter 6 is invalid, should be 1-5
Manual String parse error : invalid subtoken: 6
Manual String parse error : invalid token: 3:1-2;3:3-4;6:1-2
This happens for every title with a higher number than 5 when included in a long string like posted above.
My workaround is that if I split the string into segments, it works on an individual basis.
For Example:
6:1-2;6:3-4 does not work
but...
6:1-2 works on its own
6:3-4 works on its own
etc.
Interestingly, as long as the title number is lower than 5, which only occurs with title 3, the string works fine:
3:1-2;3:3-4
but obviously, its a pain in the ass to rip individual 15 minute episodes by opening them individually and ripping one at a time.
Anyone have a solution for this?
EDIT: Here is a log dump
MakeMKV v1.9.4 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRAM GH24NS95 RN00" opened in DASPI v1.5 mode.
Optical drive "BD-RE HL-DT-ST BD-RE BH16NS40 1.01" opened in DASPI v1.5 mode.
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'DASPI:IODASPIService:1fbfac9302cf07ab:'
ndjamena
Re: Fun with Manual Mode
#2 Post by ndjamena » Fri Jul 17, 2015 11:37 am
You separate custom titles with a SPACE not a semicolon.
/manualdvd/
ndjamena
#3 Post by ndjamena » Fri Jul 17, 2015 11:40 am
And you can name a file S01E01-02 if you need to scrape multiple episodes in a single file (it's difficult to get a player to use the metadata properly though.)
(There are other valid ways as well.)
dred1367
#4 Post by dred1367 » Fri Jul 17, 2015 12:11 pm
@ndjamena: The space worked! Thank you so much!
I'm not sure why I started using semicolons, but I do know now that the only reason its worked in the past is because all chapters were on the same title. So it was like 13:1-5;13:6-9;13:10-14 etc etc. When that title number changes though, a semicolon no longer works as a separator.
anyway, I'll probably just use the space from here on out. Thanks again for your response!
