Hi.
I try to save the movie the King's Speech,and after about the third of the movie I receive the errorsThe source file '/BDMV/STREAM/00015.m2ts' is corrupt or invalid at offset 3394957312, attempting to work around
[... many, many lines ...]
The source file '/BDMV/STREAM/00015.m2ts' is corrupt or invalid at offset 3426217984, attempting to work around
Failed to save title 1 to file /data/copie/mkv/The_King's_Speech/The_King's_Speech_t01.mkv
0 titles saved, 1 failed
Do you think that MakeMKV cannot read this movie, or is the disk broke?
Thanks,
Ghyslain
The King's Speech
Re: The King's Speech
Most likely, there is some dirt on the disk that is causing a section to be unreadable. If the errors persist past a cleaning, we can get more information.
Mike has mentioned that some combinations of drives and operating systems do not report read errors - they simply return invalid data. This can cause the "invalid or corrupt" messages, instead of SCSI read errors.
