Ex Machina and DTS:X
Jay Lucky
Post by Jay Lucky »
There is no option for copying DTS:X from the Bluray (no surprise), just DTS-HD MA. Anything needed to help add this to the next version? Happy to help since I just got mine from Amazon.
ndjamena
Re: Ex Machina and DTS:X
Post by ndjamena »
Does the track show up at all?
I don't think it would be filtering the DTS:X components from the MA track if it's listed, it just wouldn't be describing it at DTS:X because it's not programmed to tell the difference.
(unless they're different tracks...)
ndjamena
Post by ndjamena »
http://hometheaterreview.com/dts-provid ... -platform/
Backward Compatibility - DTS:X builds upon existing DTS-HD Master Audio to provide backward compatibility with existing DTS bitstreams and speaker layouts. In short, all features of DTS-HD Master Audio are supported and enable an immersive audio experience for older content.
* The DTS:X content is backward compatible with the DTS-HD decoder.
* The DTS:X decoder supports DVD, Blu-ray Disc (BD) and streaming media file formats.
* DTS:X can spatially reformat stereo, 5.1 or 7.1 content to take full advantage of all speakers in a surround system. Objects are never lost; if the object is embedded, it can be extracted and used in the rendered experience.
I'm pretty sure the second point is trying to say DTS:X is just an extension of DTS-HD.
This seems to suggest they're separate codecs on the disc though:
http://www.blu-ray.com/movies/Ex-Machin ... ay/128113/
Hmmmmm.
(it could just be listing the DTS-HD "core" stats for people who don't have a DTS:X capable receiver...)
Jay Lucky
Post by Jay Lucky »
Here's what it looks like:
And here's the full log output for loading the disc:
MakeMKV v1.9.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\XXXXXXXX/MakeMKV_log.txt
Title #00082.mpls has length of 12 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00003.mpls has length of 233 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00451.mpls has length of 280 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00700.mpls has length of 280 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00805.mpls has length of 1720 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00007.m2ts has length of 116 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00009.m2ts has length of 128 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00011.m2ts has length of 21 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00013.m2ts has length of 38 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00023.m2ts has length of 15 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00024.m2ts has length of 12 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00025.m2ts has length of 12 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00277.m2ts has length of 8 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00278.m2ts has length of 152 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00279.m2ts has length of 146 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00280.m2ts has length of 125 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00281.m2ts has length of 2399 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00282.m2ts has length of 3657 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00283.m2ts has length of 218 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00284.m2ts has length of 214 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00285.m2ts has length of 187 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00286.m2ts has length of 196 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00287.m2ts has length of 189 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00288.m2ts has length of 195 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00289.m2ts has length of 155 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00290.m2ts has length of 173 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00291.m2ts has length of 189 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00292.m2ts has length of 102 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 3700 seconds and was therefore skipped
DEBUG: Code 233 at M5rYDpUi0bsLMEB1tdRsGqa4:0
DEBUG: Code 233 at 2HcdHgKba4i7y1h12dXjQNrs:0
DEBUG: Code 233 at izVNt5Ix9IAX5eg3e5WYQxkE:0
DEBUG: Code 233 at gdSgGLVLlWC6orNR6fuKYDSf:0
DEBUG: Code 233 at jQ6thHvt3SzbEdZ+L6WI/Pbj:0
DEBUG: Code 233 at I/g0w4wI7aiA2a2RRzecgq/w:0
DEBUG: Code 233 at +WVT1A68bDNiH0zUEobwYPfZ:0
DEBUG: Code 233 at jMPuyQ+QIRPjOfwOGUZUboNT:0
DEBUG: Code 233 at su+JaAg8Yynv+rKbuQibbLrT:0
DEBUG: Code 233 at BCQ6gQXnGTTPVbtqez7t9gHD:0
I would suspect it might operate similar to Dolby Atmos where the stream is there but it presents the DTS-HD MA track as default. Would be nice to future proof my rip for when there are more receivers out that support it. I currently do not own one, but it would be interesting to hear from someone that does if DTS:X is in the stream or not...
ndjamena
Post by ndjamena »
Do a full backup, look at the files using mediainfo and see if there's anything in there that hints at another audio stream.
All those debug messages are proof enough that Mike needs to look into this properly, though.
It would be interesting to know if MakeMKV actually filters DTS-HD streams, I guess it would depend on how the stream itself is laid out.
ndjamena
Post by ndjamena »
Here we go:
http://forum.blu-ray.com/showpost.php?p ... tcount=414
I can tell you that both BDInfo and my player read the DTS: X track as having a DTS-HD MA 7.1 core, while the mix identified in the menu as "Theatrical" is in fact a lossy DTS 5.1 track.
Although if MakeMKV is just skipping a DTS:X track it's possible BDInfo would do the same thing.
MediaInfo should list "unknown" tracks as "menu" I think, but it does look like DTS, DTS-HD and DTS:X are one and the same.
ndjamena
Post by ndjamena »
You could try extracting the stream using both MKVExtract and TSMuxer and see if there's any significant size differences.
Post by mike admin »
Please submit a test dump for the tiltle with this DTS:X track per instructions at /onlinehelp/testdump.html
