An error message pops up regarding no FUT's when MakeMkv scans this disc. If I proceed and pull off the mkv for the main title the video is unwatchable - looks like a cable tv channel when the signal is having issues.
Note - I did play the disc in a Samsung Blu-Ray player to verify that the disc would play ok - so don't believe it is a disc issue.
Link to the dump file: https://dl.dropboxusercontent.com/u/549 ... 3AFA0A.tgz
Link to the debug log file: https://dl.dropboxusercontent.com/u/549 ... KV_log.txt
Longest Ride problem
Re: Longest Ride problem
Same answer as in the other message you replied to... Send the .tgz file that MakeMKV generated to svq@makemkv.com for Mike to analyze.
http://www.makemkv.com/svq/
I tried sending via email - but it gets rejected due to size - which is why I posted the download links - should be easy enough to download from those dropbox links. I sent an email with the links to those two files as well.
The email with the links works for Mike. He's not here every day.
I'm seeing this same issue. Tried pulling the svq file locally to into the "makemkv" data directory as well as letting the software pull the latest ones from the site and still no luck.
