X-Men Days of Future Past The Rogue Cut
HedgeKnight84
#1 Post by HedgeKnight84 » Tue Jul 14, 2015 8:37 pm
For this title, there was a popup stating, "BD+ code processed but no FUTs were obtained, errors may follow" and indeed they did follow; the video is unwatchable at the moment.
FYI :)
srjinatl
Re: X-Men Days of Future Past The Rogue Cut
#2 Post by srjinatl » Wed Jul 15, 2015 1:47 am
I have run into the same exact problem with The Longest Ride blu-ray.
#3 Post by Woodstock » Wed Jul 15, 2015 2:13 am
If you get the "No FUTs" message, MakeMKV should create a .tgz file, the name of which will be included in the log, which should be emailed to svq@makemkv.com for analysis. Mike can then generate an SVQ file to deal with the issue.
For more information, see: http://www.makemkv.com/svq/
HedgeKnight84
#4 Post by HedgeKnight84 » Wed Jul 15, 2015 1:24 pm
Woodstock wrote:If you get the "No FUTs" message, MakeMKV should create a .tgz file, the name of which will be included in the log, which should be emailed to svq@makemkv.com for analysis. Mike can then generate an SVQ file to deal with the issue.
For more information, see: /svq/
Just sent the e-mail. :)
thirdgen89gta
#5 Post by thirdgen89gta » Sat Jul 18, 2015 1:19 am
Also have this error, email sent with attachments.
JosephEC
#6 Post by JosephEC » Sat Jul 18, 2015 10:01 pm
Posted my info in the regular DoFP thread concerning the no FUT's error I also received with this version. Sent the dump file to support@makemkv.com. Would you prefer I send it svq@makemkv.com Mike?
#7 Post by Woodstock » Sun Jul 19, 2015 2:32 am
Either address works to get it to Mike. The SVQ address is the one he mentions in the article on FUTs and BD+, so he may be using them as a "first level" filter to separate requests.
JosephEC
#8 Post by JosephEC » Tue Jul 21, 2015 3:13 am
Fix works great, Mike! Thanks! :D
HedgeKnight84
#9 Post by HedgeKnight84 » Tue Jul 21, 2015 6:21 pm
JosephEC wrote:Fix works great, Mike! Thanks! :D
Where did you find this fix? Did Mike e-mail you, or is it posted somewhere? This is the first error I've actively tried to look into fixing, so I'm a newbie here. Thanks!
#10 Post by Woodstock » Tue Jul 21, 2015 7:45 pm
If you have checked "Allow contacting web server for updates" in the General tab of preferences, it should download any needed SVQ files when they are available.
Many people disable this as a security measure, or their firewall software will prevent it.
