X-Men Days of Future Past The Rogue Cut
HedgeKnight84
Post by HedgeKnight84 »
For this title, there was a popup stating, "BD+ code processed but no FUTs were obtained, errors may follow" and indeed they did follow; the video is unwatchable at the moment.
FYI :)
srjinatl
Re: X-Men Days of Future Past The Rogue Cut
Post by srjinatl »
I have run into the same exact problem with The Longest Ride blu-ray.
If you get the "No FUTs" message, MakeMKV should create a .tgz file, the name of which will be included in the log, which should be emailed to svq@makemkv.com for analysis. Mike can then generate an SVQ file to deal with the issue.
For more information, see: http://www.makemkv.com/svq/
HedgeKnight84
Woodstock wrote:If you get the "No FUTs" message, MakeMKV should create a .tgz file, the name of which will be included in the log, which should be emailed to svq@makemkv.com for analysis. Mike can then generate an SVQ file to deal with the issue.
For more information, see: /svq/
Just sent the e-mail. :)
thirdgen89gta
Post by thirdgen89gta »
Also have this error, email sent with attachments.
JosephEC
Post by JosephEC »
Posted my info in the regular DoFP thread concerning the no FUT's error I also received with this version. Sent the dump file to support@makemkv.com. Would you prefer I send it svq@makemkv.com Mike?
Either address works to get it to Mike. The SVQ address is the one he mentions in the article on FUTs and BD+, so he may be using them as a "first level" filter to separate requests.
JosephEC
Post by JosephEC »
Fix works great, Mike! Thanks! :D
HedgeKnight84
JosephEC wrote:Fix works great, Mike! Thanks! :D
Where did you find this fix? Did Mike e-mail you, or is it posted somewhere? This is the first error I've actively tried to look into fixing, so I'm a newbie here. Thanks!
If you have checked "Allow contacting web server for updates" in the General tab of preferences, it should download any needed SVQ files when they are available.
Many people disable this as a security measure, or their firewall software will prevent it.
