So, this is what I was talking about elsewhere.
Read the disc fine, it plays fine, it's copied successfully using Freemake, yet MakeMKV won't play with it. Here's the debug info, does anyone know what's wrong?
MakeMKV v1.9.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\G/MakeMKV_log.txt
Title #1 was added (42 cell(s), 1:40:24)
Saving 1 titles into directory G:/Movies using profile 'AAC-stereo' from file 'D:\Transient files\Programs\MakeMKV v1.9.4 Portable/aac-stereo.mmcp.xml'
DEBUG: Code 449 at a`aKZi&T*,]HMe>(1'3:213136240
DEBUG: Code 0 at w\{@|24x9z9$&`]Geg.Tv:29398967
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:213131893
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:121263406
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:29393907
Failed to save title 0 to file G:/Movies/Dark Water.mkv
0 titles saved, 1 failed
Can't copy DVD
Re: Can't copy DVD
The debug codes mean that MakeMKV encountered unexpected data, and is trying different work-arounds to make sense of things. Eventually it ran out of things to try, so it failed the rip.
"Plays fine" is not a very good test, because player software will intentionally bypass errors, but rippers do not.
Mike will have to determine what the debug codes mean.
boristm
Re: Can't copy DVD
OK Cheers. No biggy, Freemake ripped it without a problem. But I prefer to use Makemkv ya know
