Dodgy drive?
andyb
Dodgy drive?
#1 Post by andyb » Tue Jul 07, 2015 3:49 pm
Trying to rip a Bluray, tried three times but keeps on failing with the following error:
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM.
Tried the Pledge trick, no luck.
This is with a Pioneer BDR-209D
I've got twin Bluray drives, so I ripped it with a LG UHRNS30 and went through first time.
My logic is that the Pioneer is a sick puppy, anyone confirm or have any other ideas?
Re: Dodgy drive?
#2 Post by Woodstock » Tue Jul 07, 2015 6:51 pm
I'd tend to agree with you on the Pioneer being on its last legs. Or, it may just need a good cleaning.
andyb
Re: Dodgy drive?
#3 Post by andyb » Wed Jul 08, 2015 8:02 am
Thanks for the reply. To clean it, is it just a blast of compressed air or is it worth buying one if those cleaning discs? I did give the computer a good clean out the other day, so perhaps I blasted some dust into the drive, it's only 6 moths old, so unlikely to be a build up.
Re: Dodgy drive?
#4 Post by Woodstock » Wed Jul 08, 2015 2:43 pm
Blowing it out is the first step. The cleaning disks aren't all that helpful, compared to a long cotton swab and knowing where to use it.
andyb
Re: Dodgy drive?
#5 Post by andyb » Wed Jul 08, 2015 4:26 pm
Ta, I've tried blowing it out and will see what happens, cotton bud knowledge is limited to not putting it into my ear canal. As its only 6 months old I'm pretty sure it should be under guarantee anyways.
