Finding Nemo DVD
bluepiggy123
Finding Nemo DVD
#1 Post by bluepiggy123 » Wed Jul 01, 2015 11:10 am
I have tried a number of times to copy this DVD without success. It seems to read/copy a few titles but misses copying the move (it copies all the behind the scene stuff though). Has anyone had this before?
MakeMKV v1.9.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Karon/MakeMKV_log.txt
Title #1 was added (122 cell(s), 1:35:28)
DEBUG: Code 1099449 at G;#mku >l/C"mrbs$[:29400853
DEBUG: Code 30 at G;#mku >l/C"mrbs$[:213114873
Title #2 was added (170 cell(s), 2:10:42)
Title #3 was added (48 cell(s), 0:35:14)
Title #4 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #38 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39 has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #41 was added (1 cell(s), 0:02:20)
Title #42 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #43 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44 has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #47 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #48 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #49 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50 has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #51 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #52 was added (1 cell(s), 0:02:47)
Title #54 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #55 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #57 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #63 has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #64 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #65 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #67/1 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #67/2 has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #67/3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/4 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #68/5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #69 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #71 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 233 at NSwYjHyglQfKsH1qjhxCCUmM:0
Saving 5 titles into directory D:/Video/FINDING_NEMO
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204445696'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204544000'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204871680'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204892160'
DEBUG: Code 0 at k(fa4Qr>30s`i/Ch6|dd:121263038
DEBUG: Code 0 at 8pISX?V5~j -ex(zoL{:121261750
DEBUG: Code 0 at k(fa4Qr>30s`i/Ch6|dd:213130559
DEBUG: Code 100045 at k(fa4Qr>30s`i/Ch6|dd:29393286
DEBUG: Code 0 at w\{@|24x9z9$&`]Geg.Tv:29398967
DEBUG: Code 0 at a`aKZi&T*,]HMe>(1'3:29396414
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:213131893
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:121263406
DEBUG: Code 0 at ;hc$*FUkDYM]H+Uo\:29393907
Failed to save title 0 to file D:/Video/FINDING_NEMO/title00.mkv
DEBUG: Code 30 at j'yVj~><RT>p=>&lZy:213136263
DEBUG: Code 559 at j'yVj~><RT>p=>&lZy:213136286
DEBUG: Code 1560861536 at j'yVj~><RT>p=>&lZy:121268098
DEBUG: Code 610 at j'yVj~><RT>p=>&lZy:213136608
DEBUG: Code 3438837440 at j'yVj~><RT>p=>&lZy:121268420
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '92160'
DEBUG: Code 45 at k(fa4Qr>30s`i/Ch6|dd:29393286
DEBUG: Code 0 at L_TVW$R$msl/cz#LgmU:213132054
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '204982272'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '205201408'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '205309952'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '205432832'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '205529088'
DEBUG: Code 100356 at k(fa4Qr>30s`i/Ch6|dd:29393286
Failed to save title 1 to file D:/Video/FINDING_NEMO/title01.mkv
3 titles saved, 2 failed
Re: Finding Nemo DVD
#2 Post by Woodstock » Wed Jul 01, 2015 12:49 pm
This is your computer saying that it can't read part of the disk. Next step is cleaning. I'd use Pledge furniture polish to clean/wax it at the same time. Use a soft cotton or microfiber cloth.... No paper towel!
bluepiggy123
#3 Post by bluepiggy123 » Tue Jul 07, 2015 3:51 am
Thanks Woodstock but I've tried cleaning it a few times so maybe it's permanently damaged? Could the error be cause by anything else by any chance?
Tapioka
#4 Post by Tapioka » Tue Jul 07, 2015 7:31 am
I've had this error only once over the course of many, many years and it was also caused by a damaged DVD. So while I'm no expert at MakeMKV's debug messages I also share the opinion of a disk error.
